Earlier versions of ecart with CS5.5
Thread begun 7/06/2011 12:31 pm by admin140217 | Last modified 7/06/2011 3:23 pm by Jason Byrnes | 2563 views | 5 replies |
admin140217
Just a quick question,
Will the earlier versions of ecart (I think version 2?) that worked with ASP compatable with Dreamweaver CS5.5?
I also am using DW CS4, are there any compatability issues there?
I have an older ecommerce site I need to update and it is an ASP site.
No, eCart 2 is not compatible with either CS4 or CS5.5.
I believe the latest version that eCart 2 is compatible with is DW8.02
admin140217
What about ecart 3? I do have this version also which haadles ASP, are there compatability issues with CS4 or CS5.5?
Thanks,
NO, eCart 3 is not compatible with CS4 or CS5.5 either,
you will need to use an earlier version of Dreamweaver to use either of those versions of eCart.
admin140217
Thanks Jason!
you're welcome.
