Virtual error message
Thread began 7/05/2011 3:29 pm by richard370782 | Last modified 7/06/2011 8:23 am by Jason Byrnes | 781 views | 1 replies |
richard370782
I am using the full supersuite and in particular using SecurityAssist version: 1.1.9. When I create my code adn up load it to my hosting testing server - godaddy.com I get the following error
Fatal error: Call to undefined function virtual() in /home/content/m/a/x/maximus/html/memberarea/90days.php on line 1
The code that Security Assit creates is
<?php virtual( "/WA_SecurityAssist/Helper_PHP.php" ); ?>
When I change the code by hand to
<?php include("/WA_SecurityAssist/Helper_PHP.php" ); ?>
Warning: include(/WA_SecurityAssist/Helper_PHP.php) [function.include]: failed to open stream: No such file or directory in /home/content/m/a/x/maximus/html/memberarea/90days.php on line 1
Warning: include() [function.include]: Failed opening '/WA_SecurityAssist/Helper_PHP.php' for inclusion (include_path='.:/usr/local/php5/lib/php') in /home/content/m/a/x/maximus/html/memberarea/90days.php on line 1
If I place directory ".." before the "/" it works
I really don't want to have to hand change every line of code in this site. Can anyone offer any suggestions?
Richard
In your Dreamweaver Site Settings, on the Local Info tab, there is an option to "Create Links relative to", if you set this option to "Site" Dreamweaver will use the virtual() function for attaching included files, if you set this to "Document instead, Dreamweaver will use the require_once() function.
