Simple checkbox on Results page issue
Thread begun 7/05/2011 9:17 am by Jared Lui | Last modified 7/07/2011 7:07 am by Jason Byrnes | 4108 views | 7 replies |
Jared Lui
I am using an INSERT page to successfully add a Y or N value to my database "Approved" column using a checkbox.
I have the checkbox working correctly on the UPDATE and DELETE pages. And it shows fine in the results table correctly.
My issue is between the SEARCH and RESULTS where the filter is concerned. My results table is showing all records ignoring the "Approved" column.
I have the Search checkbox checked by default so that is always show all approved results.
This is from saerch.php:
<input name="Approved" type="checkbox" id="Approved" value="Y" checked="checked" />
This is the business end of the search URL:
Results.php?S_Line_Name=&S_Line_Nickname=&S_Start_Decade=&S_End_Decade=&S_Manufacturer=&S_Size=&S_Cat_1=&Approved=Y&S_Added_By=&S_Line_Text=&Search.x=30&Search.y=20&Search=Search
This is the comparison list additions how I would think it would work:
$WADbSearch1->addComparisonFromCheck("Approved","S_Approved","Y","","AND","=","=",1);
Used column type: boolean; Type: Check; check field name: S_Approved; Checked value: = Y
Tried many different combinations and none worked. Did some forum searches and found someone having simular issues and they were told to use: Type Edit and make sure Search value is Y. That didn't help me.
I know I am missing something simple but I am over looking it obviously.
I want to be able to have my search only return those records that have a Y in the Approve column.
Thanks in advance for your help.
send a copy of the results page please.
Jared Lui
Here is the results file.
when troubleshooting search issues, the first thing is to add code to your page to output the SQL being executed.
add the following code just after the <body> tag on your page:
<?php echo"SQL: ".$query_limit_WADAfigure_lines."<br />"); ?>
and post back the sql being executed, the search querystring is also helpfull as well.
Jared Lui
Here is the SQL. I normally add this to my search pages and leave it there, a tip I picked up from you awhile back.
SQL: SELECT Line_Id, Line_Name, Line_Nickname, Start_Decade, End_Decade, Manufacturer, Size, Cat_1, Cat_2, Cat_3, Approved, Locked, Added_By, Line_Text FROM figure_lines WHERE (Approved = 0) AND (Locked = 0) ORDER BY Line_Name ASC LIMIT 0, 10
I know the WHERE statement is saying "= 0" but I don't see where that is happening. Maybe I am thinking about this wrong but I though by having the checked value = Y on the search page that it would send that value in the URL. So I'm guessing the issue is on the Results page?
Thanks.
in the DataAssist Search wizard, the Column Type for the Approved and Locked column criteria is set to Number/Boolean. change it to text.
Jared Lui
Thanks Jason. That solved half of my issue. I keep mistakenly associating Y/N with Boolean but think I'll remember from now on.
BTW, my David Powers books should arrive today and I took the SQL course in W3Schools and started the Javascript and Php lessons. Great advice!
My other issue was noticing once I change Boolean to text that the SQL was returning "=N" regardless of what the searched check boxes were. I left off the "S_" in the check field name. I new I was missing simple items. A hazard for a noob trying to retrofit after the fact.
Thanks again Jason.
no worries, glad to hear you got it working.
