UE4 & Logging - 500 error but get email
Thread begun 7/04/2011 1:41 pm by julie383376 | Last modified 7/04/2011 3:28 pm by julie383376 | 1735 views | 1 replies |
julie383376
I created a test form, submitted it, received all emails (to, from, cc), and the record wrote to the database.
I then added the functionality to a different form on the same domain. The emails were sent/received, but I got a page that says "HTTP Error 500.0 - Internal Server Error", and no data was written to the database.
So I tried the original test form to see if maybe I had done something wrong in creating this new form, but this form gave the same result as the second form - email sent, 500 error.
This is above my skillset, but my sister (who teaches programming) says it sounds like something that happens with her students a lot - which is, they didn't "close" the connection to the database after writing the record (? - did I say that right?) Could I have done something in my testing that made that happen?
I am an administrator on our webserver, so I set up Failed Request Tracing, and have a logs that you can see if it will help. I only see a warning for event "MODULE_SET_RESPONSE_ERROR_STATUS" in FastCgiModule
It says:
ModuleName: FastCgiModule
Notification: 128
HttpStatus: 500
HttpReason: Internal Server Error
HttpSubStatus: 0
ErrorCode: 0
ConfigExceptionInfo:
Notification: EXECUTE_REQUEST_HANDLER
ErrorCode: The operation completed successfully. (0x0)
There is no other error or warning in the rest of the log.
Can you help? Or do you need more info / screenshots / whatever...?
As always, thank you in advance for your help!
~J
julie383376
Fixed! Missing library.php file
I thought I had looked at all error logs on the server, but I missed one.
The PHP error log showed "Failed opening required 'library.php' "
Sure enough, the script had not installed that file in my webassist/database_management folder
It was in the ..configuration/shared/webassist... (path shortened) location, but it wasn't in my site. I have no idea how the form worked the first time, but after I copied the file into my site, the form submitted, no 500 error page, and it wrote to the database.
I love spending hours and hours and hours troubleshooting (holiday weekend, no less), only to find out that a file that should have been there wasn't...
~J
