Dropdown not adding to cart
Thread begun 7/08/2009 9:47 am by dacker1313513 | Last modified 7/09/2009 2:56 pm by Ray Borduin | 5205 views | 7 replies |
dacker1313513
New to eCart so bare with me.
I have a site where a customer can choose from a dropdown list, click on the "Add to cart" button (I used a custom image for this) for different size items.
The problem: regardless of which size the customer chooses, it always places the same item in the cart. Here is link to one of the pages so you can see what's going on.
hairMoist.php. If you try it you'll see what I mean.
I'm sure there's a way to do this I just don't have the experience.
Thanks.
vela1606379889
Hi Dacker,
I'm looking to figure out the same thing. I looked at your code, specifically this part,
<div id="rtBottomContent">
<p class="RMbottom">
<select>
<option>16 oz. Hair Moisturizer</option>
<option>32 oz Hair Moisturizer</option>
<option>Gallon Hair Moisturizer</option>
<option>5 Gallon Hair Moisturizer</option>
</select>
<form name="LBI_1_ATC_7.95" method="POST" action="/Dealers/hairMoist.php">
<input type="hidden" name="LBI_1_ID_Add" value="7.95" >
<input type="hidden" name="LBI_1_Description_Add" value="16 oz. Hair Moisturizer" >
<input type="hidden" name="LBI_1_Weight_Add" value="1.1" >
<input type="hidden" name="LBI_1_Quantity_Add" value="6" >
<input type="hidden" name="LBI_1_Price_Add" value="7.95" >
<input type="image" src="images/button.jpg" align="right" border="0" value="Add to Cart" name="LBI_1_ATC">
</form>
</p>
</div>
You can see there how your add to cart button is only setup for the 16 oz. bottle. Somehow, when the user selects a different product that needs to change to reflect the change but it doesn't. I know that's probably not much help, but maybe it's a starting point for where to investigate. I'm very new to this to, so sorry I can't provide more insight.
You would probably set the option value to a key field that you could use to filter a recordset and then reference that recordset when doing the add to cart.
dacker1313513
Would that look something like this:
<option value="description">16 oz. Hair Moisturizer</option>
etc.
etc.
etc.
Or am I looking at the wrong thing.
I would think something like:
<option value="1">16 oz. Hair Moisturizer</option>
<option value="2">32 oz Hair Moisturizer</option>
<option value="3">Gallon Hair Moisturizer</option>
<option value="4">5 Gallon Hair Moisturizer</option>
Then in your database you have a table of options with
ID, Name, Price
you can then filter a recordset with the submitted list value and return the associated option name and price from a single list. Then bind those fields in the cart from the recordset you have created.
dacker1313513
Thanks Ray for your time. I guess I'm going to have to go back to school for this eCart program. I've tried for 6 hours today and the results are the same. Here's a look at my code.
<select>
</select>
<form name="LBI_1_ATC_<?php echo $row_rsHairMoist['ID']; ?>" method="POST" action="<?php echo $_SERVER["PHP_SELF"]; ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".$_SERVER["QUERY_STRING"]:""; ?>">
<input type="hidden" name="LBI_1_ID_Add" value="<?php echo $row_rsHairMoist['ID']; ?>" >
<input type="hidden" name="LBI_1_Description_Add" value="<?php echo $row_rsHairMoist['Description']; ?>" >
<input type="hidden" name="LBI_1_Weight_Add" value="<?php echo $row_rsHairMoist['Weight']; ?>" >
<input type="hidden" name="LBI_1_Quantity_Add" value="<?php echo $row_rsHairMoist['Dealer_Qty']; ?>" >
<input type="hidden" name="LBI_1_Price_Add" value="<?php echo $row_rsHairMoist['Dealer_Price']; ?>" >
<input type="image" src="images/button.jpg" border="0" value="Add to Cart" name="LBI_1_ATC">
</form>
</p>
</div>
That part looks good. Now you need to create the recordset to look up the price and name based on the option value.
dacker1313513
I see. The code your showing me is what the PHP pulls from the server. Never thought to look at that.
Here's how it looks in Dreamweaver:
<select>
</select>
<form name="LBI_1_ATC_<?php echo $row_rsHairMoist['Dealer_Price']; ?>" method="POST" action="<?php echo $_SERVER["PHP_SELF"]; ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".$_SERVER["QUERY_STRING"]:""; ?>">
<input type="hidden" name="LBI_1_ID_Add" value="<?php echo $row_rsHairMoist['Dealer_Price']; ?>" >
</form>
</p>
</div>
