Show details with advance recordset
Thread begun 7/02/2011 8:27 am by wbrooks199805 | Last modified 7/10/2011 11:18 am by CraigR | 7059 views | 26 replies |
wbrooks199805
I have 2 tables. One "members" and the other "naics". I have 6 different items in members (serviceone, servicetwo, servicethree, servicefour, servicefive, servicesix) and trying to call in the naicsTitle from naics. I know how to call in one item from the naics table but when I try 2 it doesn't work.
I know this isn't the answer below in select but the first one will work for naicsTitle but after that I am stuck.
SELECT naicsTitle, serviceone, servicetwo, servicethree, servicefour, servicefive, servicesix
FROM members
JOIN naics ON members.serviceone = naics.naicsNum AND members.servicetwo = naics.naicsNum
CraigRBeta Tester
can you explain what kind of data each table holds and the relationship between them ?
is the naics table essentially a reference table ?
can members hold more than one naics code ?
wbrooks199805
questions and answers
RE: One is members database. Second is a division of their company
RE: It is a dropdown menu of all their divisions
Table Name: naics
naicsNum, naicsTitle
RE: Members can have up to 6 divisions. If you look at the select area you can see that serviceone, servicetwo, etc. are part of the members table and those would be the divisions.
CraigRBeta Tester
I think I see what you are trying to do.
You probably need to re-think your table structure
Your members table doesn't need the naics number columns
Create a new table 'membernaics' with the following columns..
membernaicsid, (PK, auto)
memberid
naicsid
say, member 1 has naics 7, 8 and 9
the data would be
membernaicsid : memberid : naicsid
1:1:7
2:1:8
3:1:9
to retrieve the naicstitle for each member
SELECT member, naicstitle FROM members JOIN members ON membernaics.memberid = membernaics.memberid JOIN naics ON membernaics.naicsid = naics.naicstitle
This also allows you to have as many naics items per member as you wish
wbrooks199805
I'll give it go
Thanks..will give it a shot tomorrow.
Wait a minute..FROM members JOIN members? That doesn't make sense to me..can you do that?
wbrooks199805
Not a unique table
I was right. You can't use because you can't have FROM members and JOIN members because its not a unique table.
Any other ideas? I have tried a few different ways of doing this but can't get any of them to work.
CraigRBeta Tester
sorry, for the typos.
not certain of your field names but try this..
SELECT member, naicstitle FROM members JOIN membernaics ON members.memberid = membernaics.memberid JOIN naics ON membernaics.naicsid = naics.naicsid
wbrooks199805
screen shot
I changed it to the correct names but the values are not coming back correctly when I tested the server. It should have different values in the title for the naicsTitle as they are different.
SELECT memNum, naicsTitle
FROM members JOIN membernaics ON members.memNum = membernaics.memberid JOIN naics ON membernaics.naicsid = naics.naicsNum
wbrooks199805
Okay so this works but now..
This works.
SELECT memNum, naicsTitle, servicesone, servicetwo, servicethree, memberid, naicsid
FROM members JOIN membernaics ON members.memNum = membernaics.memberid JOIN naics ON membernaics.membernaicsid = naics.naicsNum
But now I need to have the update and input page work. How do I set up that record set?
This needs to input that info into the membernaics table?
This is what I have now.
SELECT naicsNum, naicsTitle
FROM naics
CraigRBeta Tester
OK, just to ensure we're not talking at cross purposes...
i have created a database with 3 tables, as laid out in the attached file, which you need to unzip
using phpmyadmin, add the tables and query them as follows...
SELECT membername, naicsdescription FROM member JOIN membernaics ON member.memberid = membernaics.memberid JOIN naics ON membernaics.naicsid = naics.naicsid
or for all of the fields...
SELECT * FROM member JOIN membernaics ON member.memberid = membernaics.memberid JOIN naics ON membernaics.naicsid = naics.naicsid
you result set should look like this
