DW Extensions with the Same Features
Can you give me the list of all DW extensions with the same features to avoid the overlapping problems.
Thanks,
Thanks,
Universal Email 4 - Contains: Universal Email / Digital File Pro
CSS Form Builder - Contains: Universal Email / Digital File pro / HTML Editor 2 / validation Toolkit (Can be upgraded by installing HTML Editor 3 as long as the HTML editor compatibility build is installed first)
Form Toolkit - Contains: Validation Toolkit (can be installed alongside CSS Form Builder
Security Assist - Contains: Validation Toolkit and limited functionality from universal Email and DataAssist (can be installed along side form builder, form toolkit, data assist and universal email)
Thanks Jason,
Can you give me the right sequence of the following extensions: ( FB, FT, SA, DA ) Thanks again.
How about in Form Builder 2.0.1 and HTML Editor 3.0.2 ?
What should be the first to installed ? Thanks
Install Form Builder 2.0.1, then HTML HTML Editor 3.0.2
