Restrict Page Access Error
Thread begun 6/30/2011 9:28 am by hbibizadeh396670 | Last modified 6/30/2011 11:25 am by Jason Byrnes | 3097 views | 5 replies |
hbibizadeh396670
I have created an admin back end to my site, which works fine on all pages but one.
When a user clicks the admin link, they should be directed to login or the admin cp depending on if they have already logged in.
The issue is that if a user has not logged in already, the page does not redirect them to login. Instead I just get a blank page. (As Seen in screen shot)
I know I have implemented the system (Admin/User Levels) correctly as I have made it work on all other pages and done it many times in the past.
I think its an issue with the code on the page somehow but do not know what.
I attached the page.
How do I fix this?
a blank page means there is a php error but error reporting is turned off.
add the following code at line 1 of the page to turn error reporting on:
error_reporting
(E_ALL);
once we know what the error is, we can troubleshoot the cause.
hbibizadeh396670
Here is my error:
Warning: session_start(): Cannot send session cache limiter - headers already sent (output started at /customers/ashperfectimage.com/ashperfectimage.com/httpd.www/Siteezy_eCart2/UserRegistrationSystem/AdminCP.php:1) in /customers/ashperfectimage.com/ashperfectimage.com/httpd.www/Siteezy_eCart2/WA_SecurityAssist/Helper_PHP.php on line 5 Warning: Cannot modify header information - headers already sent by (output started at /customers/ashperfectimage.com/ashperfectimage.com/httpd.www/Siteezy_eCart2/UserRegistrationSystem/AdminCP.php:1) in /customers/ashperfectimage.com/ashperfectimage.com/httpd.www/Siteezy_eCart2/WA_SecurityAssist/Helper_PHP.php on line 67
that is the headers already sent error.
see this portion of the error:
it is saying that the output is at line 1 of the AdminCP.php page
See the following page for details on the headers already sent error:
showthread.php?t=19285
Read through the entire post, your problem is most likely the BOM Unicode Signature bug mentioned at the end.
hbibizadeh396670
Ok
I think it is the BOM Unicode Signature.
I looked at it and it is checked.
However it will not allow me to UN check it. It is UN clickable
Could you tell me how to uncheck it in the code it another way
you cannot set the unicode BOM option through page code.
open it in another text editor like Text Wrangler and go to Save as, most text editors have an option for changing the encoding that you can select, for example in text wrangler there is an encoding option for UTF-8, No BOM
