DA Search not returning results when there are spaces between search criteria
Thread begun 6/29/2011 7:39 am by sandy170299 | Last modified 6/29/2011 11:15 am by Jason Byrnes | 3077 views | 7 replies |
sandy170299
When a client searches for Forest, for example, a whole bunch of results are returned, including the following:
Forest Lake Times, Forest Engineering, Forest Hills Restaurant, Forest Lake Airport, etc.
But if she types in Forest Lake, for example, nothing is returned. Nothing at all. Do you need to see my search page code?
Thank you!
How is the criteria set in the Data Assist Search wizard?
Try setting comparison to includes and the Filter type to Keyword, set the OR separator to be a space " ", and set the AND separator t be a comma+space ", "
this way the search term "Forest Lake" becomes:
WHERE column LIKE "%Forest%" OR column LIKE "%Lake%"
or if you search for "Forest, Lake" it becomes:
WHERE column LIKE "%Forest%" AND column LIKE "%Lake%"
sandy170299
This is the search code currently:
<cfscript>
//WA Database Search (Copyright 2005, WebAssist.com)
//Recordset: WADAdbotblDonations;
//Searchpage: tblDonations_Search.cfm;
//Form: WADASearchForm;
WADbSearch1_DefaultWhere = "";
WADbSearch1_SetSession = "";
if (isDefined("URL.Search.x") AND URL.Search.x NEQ ""){
WADbSearch1 = FilterDef("SQL SERVER");
//keyword array declarations
//comparison list additions
WADbSearch1 = addComparisonFromEdit(WADbSearch1,"last_name","S_donorID","","Includes",0);
WADbSearch1 = addComparisonFromEdit(WADbSearch1,"company","S_company","OR","Includes",0);
//end comparison additions
if (1 EQ 1){
WADbSearch1_SetSession = "WADbSearch1_tblDonations_Results";
else {
if (1 EQ 1){
if (IsDefined("Session.WADbSearch1_tblDonations_Results")){
//get session query
WADbSearch1.whereClause = Session.WADbSearch1_tblDonations_Results;
else{
//use default query
WADbSearch1.whereClause = WADbSearch1_DefaultWhere;
else{
//use default query
WADbSearch1.whereClause = WADbSearch1_DefaultWhere; }
WADbSearch1.whereClause = WA_Replace(WADbSearch1.whereClause, 'WHERE');
</cfscript>
right,, none of those are keyword search types.
like i said initially:
[quote]
Try setting comparison to includes and the Filter type to Keyword, set the OR separator to be a space " ", and set the AND separator to be a comma+space ", "
[quote]
sandy170299
Jason, that didn't work. Now it's returning all the results, with no filtering.
please send a copy of your page so I can see the code and a link where i can test this in the browser.
sandy170299
Jason, I'll have to send the URL and login credentials to you privately, as it's in a secure area of the web site. Do you need to open a support ticket, or should I just email it to you?
