image offset to right
Thread begun 6/24/2011 4:05 am by CraigR | Last modified 6/27/2011 12:29 pm by neilo | 3625 views | 6 replies |
CraigRBeta Tester
I just got around to updating powergallery because of browser issues with new version of FF.
My gallery is ribbon/fullsize/lightbox.
After the upgrade, the fullsize image is overhanging my content div and appearing well to the right, which I am sure wasn't happening before.
I do remember seeing something like this before, but can;t remember what I did.
I kept my old css files to compare, but they seem to be identical
example..
ecommerce.php
in the galleries/ribbon_fullsize_lightbox/css/common.css adjust the width for the following properties:
.pg-rfl
.pg-rfl .fullsize
.pg-rfl .fullsize .fullsize-enlarge
CraigRBeta Tester
Thanks Jason, that has nearly fixed it.
The only thing I cannot fix, is the width of the ribbon, which seems to be set in js for the fullsize+ribbon+lightbox
I have edited the css class, and previewed the ribbon width through firebug, but the width stubbornly refuses to change permanently
I have edited the gallery.js to change the number of thumbnails displayed, which helps, but the width doesn't match the div above
the ribbon width is set dynamically based on the number of thumbnails.
you can change the number of thumbnails in the ribbon by editing the galleries/ribbon_fullsize_lightbox/js/gallery.js file
find the following code:
options: {
initial: 0,
perPage: 6
the perPage setting sets the number of thumbnails to show in the ribbon.
CraigRBeta Tester
As per my last message. I already did this...
but the width of the ribbon doesn't match the div above
it looks worse because of the border, is it easier just to remove the border and centre the ribbon ?
since the width is dynamically generated based on the number of thumbnails, you cant really change the width of the ribbon.
centering the ribbon is one solution, another solution is to change the width of the main image to match the width of the thumbnails.
neilo
In your galleries/ribbon_fullsize_lightbox/index.php file, could you not set an inline style width (491px) for the div class="thumbs-wrapper" div?:
<div class="thumbs-wrapper" style="width: 491px;">
then set the class="thumbs" margin style to auto?
<div class="thumbs" style="width: 474px; margin:auto">
