Best approach for multiple coupons?
Thread begun 6/23/2011 1:37 am by CraigR | Last modified 1/20/2015 3:12 pm by Patrice | 11569 views | 39 replies |
CraigRBeta Tester
I have a number of discount coupons, each which use the same session variable, eg $_SESSION['coupon'] whose value is set by using a form text field on the cart page.
This works great for individual discounts, but is a bit limiting if a customer has several valid coupon codes.
eg if code 1 gives 10% off power tools, and code 2 offers free shipping over $100, I want to enable the customer to use both codes in the same transaction
first, edit the set session value code so an array is created of the coupon session variables by changing the name of the session from:
$_SESSION['coupon']
$_SESSION['coupon'][]
for example:
if (!session_id()) session_start();
if((((isset(
$_POST["coupon"]))?$_POST["coupon"]:"") != ""))     {
$_SESSION["coupon"][] = "".((isset($_POST["coupon"]))?$_POST["coupon"]:"")  ."";
then create a discount rule for each possible coupon code. For the trigger, select "custom expression" and add the following code:
isset($_SESSION["coupon"]) && in_array("12345",$_SESSION["coupon"])
where "12345" is the coupon code.
CraigRBeta Tester
excellent.
Thanks Jason
you're welcome.
graham
I also would like to allow multiple coupon codes, but require a little clarification
Jason, I have followed this thread but haven't been able to activate multiple coupons at once; I have two that work independently of each other.
My question is this: I followed the eCart - "Adding coupons to your cart" tutorial and it created the eCart Set Session Value, which reads:
if((((isset($_POST["txtPromoCode"]))?$_POST["txtPromoCode"]:"") != "")) {
$_SESSION["PromoCode"] = "".((isset($_POST["txtPromoCode"]))?$_POST["txtPromoCode"]:"") ."";
In this thread, you advise on adding [] to the Session, in my case:
$_SESSION["PromoCode"][] = "".((isset($_POST["txtPromoCode"]))?$_POST["txtPromoCode"]:"") ."";
When I do make this change, the eCart Set Session Value in my server behaviours, disappears (?)
As for the custom expression trigger, I assume it is added to the end of the merchandising rule I created ... what is the separator - AND/OR? And, in this expression, the "coupon" variable for me would be PromoCode, or is it txtPromoCode in this case?
There is probably a simple logic to this that I am missing ... but I am close to the completion of my site, and my brain is rebelling a bit.
yes, converting the code to create an array of the coupon codes will cause the server behavior to not show in the server behaviors panel
The idea is that by adding [] to the end of the session variables name, it is now creating an array.
The custom trigger code to use would be:
isset($_SESSION["PromoCode"]) && in_array("12345",$_SESSION["PromoCode"])
This custom trigger is a replacement of the trigger that is used in the tutorial.
graham
Great ...
Good explanation ... when adding the custom trigger to the rule(s), do I simply add it below my existing triggers for each of the merchandising rule(s)?
What happens with the operator? AND/OR?
Thanks, as always, for the quick replies!
no, like i said, the custom trigger is a replacement for the other triggers, not in addition to.
graham
The mistake I seem to be making, is in trying to add this trigger to the discount rule definition; if I replace the other triggers (i.e. "SubTotal of items < 100" or "total number of items > 0"), how will the rule be defined?
So you want the discount to apply only if the Subtotal is less than 100? you need to include this sort of detail in your questions for me to be able to give accurate answers.
your rule:
doesn't make sense. using OR "total number of items > 0" will cause the discount to apply whether the subtotal is under 100 or not.
it should be:
AND
AND
Custom Condition: isset($_SESSION["PromoCode"]) && in_array("12345",$_SESSION["PromoCode"])
