file upload does not work on update page.
Thread begun 6/22/2011 6:47 am by Base5 Designs | Last modified 6/23/2011 9:37 am by Base5 Designs | 3347 views | 8 replies |
Base5 Designs
Hi exactly what the titlesays i cant upload a file on an update page.
have added the debugging code that i found on other threads this is what i get:
SQL: UPDATE `products_prd` SET `name_prd` = 'As Laxas', `idtyp_prd` = 82, `idcon_prd` = 9, `idreg_prd` = 23, `idwns_prd` = 35, `year_prd` = 1995, `shortdesc_prd` = 'Intense floral and fruit aromas, especially bananas and apricots. Wonderfully fresh on the palate with a well adjusted acidity balanced by the wine’s body.', `longdesc_prd` = 'Intense floral and fruit aromas, especially bananas and apricots. Wonderfully fresh on the palate with a well adjusted acidity balanced by the wine’s body.', `image_prd` = '', `price_prd` = 9.75, `onsale_prd` = 0, `saleprice_prd` = NULL, `special_prd` = 0, `wotm_prd` = 0, `active_prd` = 1, `slug_prd` = 'as-laxas' WHERE `id_prd`=33
default file:
Debug Info:
Status object: WA_UploadResult1
statusCode : 0
errorMessage : No file uploaded
clientFileName :
fileExtension :
serverFileName :
serverSimpleFileName :
serverDirectory :
contentType :
fileWasOverwritten :
fileWasSkipped :
fileWasRenamed :
fileSize : -1
isImage :
imageWidth : -1
imageHeight : -1
WA_UploadResult1_1:
clientFileName :
fileExtension :
serverFileName :
serverDirectory :
contentType :
fileSize : -1
imageWidth : -1
imageHeight : -1
statusCode : 0
have attached my page in a zip,
I am so behind on this project now, with all the problems of security assist, form builder, and now i have to wait another day for this problem, not good productivity :(
and i havent even started to implement ecart yet......
line 205:
WA_DFP_UploadFiles("WA_UploadResult1", "image_prd", "2", "[NewFileName]_[Increment]", "true", $WA_UploadResult1_Params);
is telling it to use the hidden form element "image_prd" as the file feild.
the code should be using the new_image form element which is the actual file field on the page.
WA_DFP_UploadFiles("WA_UploadResult1", "new_image", "2", "[NewFileName]_[Increment]", "true", $WA_UploadResult1_Params);
also, the default file setting is set to use the image_prd recordset binding, it should be using the image_prd form element.
Base5 Designs
hi jason, thanks for your reply
i removed the upload behaviour and reapplied it to the new_image file field setting the deafault image from the WADAUpdateForm binding of the hidden field image_prd
still not working
this is my code for the upload now:
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "/assets/images/",
'FileName' => "[FileName]",
'DefaultFileName' => "".((isset($_POST["image_prd"]))?$_POST["image_prd"]:"") ."",
'ResizeType' => "0",
'ResizeWidth' => "120",
'ResizeHeight' => "120",
'ResizeFillColor' => "#FFFFFF" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if(isset($_POST["Update_x"])){
and this is the output
default file:
Debug Info:
statusCode : -1
errorMessage :
clientFileName :
fileExtension :
serverFileName :
serverDirectory :
contentType :
fileWasSkipped :
fileWasRenamed :
fileSize : -1
isImage :
imageWidth : -1
imageHeight : -1
WA_UploadResult1_1:
clientFileName :
fileExtension :
serverFileName :
serverDirectory :
contentType :
fileSize : -1
imageWidth : -1
imageHeight : -1
next thing to check is that there is not a php error occurring.
add the following code at line 1:
error_reporting
(E_ALL);
And add this code just after the <body tag to output the FILES array:
<pre><?php var_dump($_FILES); ?></pre>
Base5 Designs
Hi Jason
Its a production box and error reporting is on, no errors appearing in any of the code
i added the extra code and output is now this:
array
'new_file' =>
array
'name' => string 'wine_1098966596.jpg' (length=19)
'type' => string 'image/jpeg' (length=10)
'tmp_name' => string 'C:\WINDOWS\Temp\php211A.tmp' (length=27)
'error' => int 0
'size' => int 2940
SQL: UPDATE `products_prd` SET `name_prd` = 'As Laxas', `idtyp_prd` = 82, `idcon_prd` = 9, `idreg_prd` = 23, `idwns_prd` = 35, `year_prd` = 1995, `shortdesc_prd` = 'Intense floral and fruit aromas, especially bananas and apricots. Wonderfully fresh on the palate with a well adjusted acidity balanced by the wine’s body.', `longdesc_prd` = 'Intense floral and fruit aromas, especially bananas and apricots. Wonderfully fresh on the palate with a well adjusted acidity balanced by the wine’s body.', `image_prd` = '', `price_prd` = 9.75, `onsale_prd` = 0, `saleprice_prd` = NULL, `special_prd` = NULL, `wotm_prd` = 0, `active_prd` = 1, `slug_prd` = 'as-laxas' WHERE `id_prd`=33
default file:
Debug Info:
statusCode : -1
errorMessage :
clientFileName :
fileExtension :
serverFileName :
serverDirectory :
contentType :
fileWasSkipped :
fileWasRenamed :
fileSize : -1
isImage :
imageWidth : -1
imageHeight : -1
WA_UploadResult1_1:
clientFileName :
fileExtension :
serverFileName :
serverDirectory :
contentType :
fileSize : -1
imageWidth : -1
imageHeight : -1
Update Product
I created a dummy page with the same set-up for the file and hidden field as on this page
applied the upload on and it worked fine.
so i copied that code into the doc i am working on, and it doesn't work, so something on this page is breaking it. am guessing its the html editor am certain i had installed the beta css form builder then html editor 3 after, but whn i looked in extension manager the version was said 2.0.0 so too make sure i uninstalled security assist, form builder form toolkit and html editor 3.
reinstalled them in this order:
Form Toolkit
Form Builder 2.0.1
HTML Editor 3
Security Assist 2.1
am about to try to reapply the upload and html editor to the page and see if this solves it.
i know you guys are not going to be about for a few days, which is a shame i really would like to have this sorted before the weekend as i need to show my client something on monday, this issue is holding up completion of the cms for the site :(
appreciate your time, i will report back if re-installing extensions has helped either way.
this:
array
'new_file' =>
array
'error' => int 0
'size' => int 2940
indicates that the name of the file field is "new_file"
but this code:
is looking for a file field named "new_image"
when you add the image upload behavior, are you typing the name for the file field? or are you selecting it from the drop down list? you should be selecting it from the drop down list. and after the upload has been applied, do not rename the file field.
Base5 Designs
Hi jason
yes the code changed but is still correct as i said i created an upload on a blank page, and this worked so i copied the code across:
i am selecting the field from the dropdown.
the code now reads:
WA_DFP_UploadFiles("WA_UploadResult1", "new_file", "2", "[NewFileName]_[Increment]", "true", $WA_UploadResult1_Params);
and the associated form elements:
<label for="image_prd"></label>
<input type="hidden" name="image_prd" id="image_prd" value="<?php echo(str_replace('"', '&quot;', $row_WADAproducts_prd['image_prd'])); ?>"/>
<label for="new_file"></label>
<input type="file" name="new_file" id="new_file" />
and this is the output:
array
'new_file' =>
array
'error' => int 0
'size' => int 2940
default file:
Debug Info:
statusCode : -1
errorMessage :
clientFileName :
fileExtension :
serverFileName :
serverDirectory :
contentType :
fileWasSkipped :
fileWasRenamed :
fileSize : -1
isImage :
imageWidth : -1
imageHeight : -1
WA_UploadResult1_1:
clientFileName :
fileExtension :
serverFileName :
serverDirectory :
contentType :
fileSize : -1
imageWidth : -1
imageHeight : -1
Update Product
Base5 Designs
Thanks For your time jason, i really appreciate it.
For anybody wondering what the issue was as ususal something very simple.
i was using an absoloute path for the upload, which was causing the problem.
so if you have similar issues check that you are using document relative paths.
i was using a absolute path as the update page was a plug-in used by the framework builder.
I thought it would take the path from the page the framework builder was applied too.
this is not the case:
in fact it appears that the framework builder when including plugins, will process the plugin from the folder it resides in so using a path relative to the plug-in page is the correct way forward.
