Editor dissapears after upgrading frm v2 to v3
Thread began 6/21/2011 5:18 am by Paul | Last modified 6/22/2011 6:51 am by Jason Byrnes | 1403 views | 3 replies |
PaulBeta Tester
I was using v2 HTML editor on my form page.
When I upgraded to to v3.02, edited the form again and uploaded, half my page including the form disappeared.
Attached is the code used for v3 and v2.
After I returned the code back to v2 my page returned in full including form, but the editor toolbar was missing.
Have I missed something here?
Thanks, Paul.
HTML Editor 2.02.txt
HTML Editor 3.02.txt
make sure that the entire webassist folder is uploaded to the server.
if you are still having a problem, add the following code at line 1 to turn on error reporting to see if a php error is occurring:
error_reporting
(E_ALL);
also, view source on the page to see if there are errors showing in the source that you would not see otherwise
PaulBeta Tester
I re-uploaded webassist folder and cured the problem.
Thank you.
you're welcome.
