Logout - Clears everything including Cart
How can I create the logout to only clear the SA login and not the shopping cart session?
go to the login page and double click the Security Assist Authenticate User server behavior, on the 3rd page of the wizard, make not of the names of the session variables that are created on login, then click cancel.
now open the logout page and double click the Clear Session Value server behavior.
change it from Clear All, to Clear These, and select the sessions that are created on login.
Thanks, Jason.
One more question. This particular site was built with SA 1, will there be any issues if I update it with SA 2? I think the only thing that I'll be changing is the password reset.
Thank again.
no, there should not be any issues updating a site created using SA1 with SA2.
