Message sent with or without CAPTCHA
Thread begun 6/20/2011 5:50 pm by lwade-bahr409715 | Last modified 6/30/2011 7:31 am by Jason Byrnes | 4499 views | 7 replies |
lwade-bahr409715
Hello.
My form is sending an email with or without CAPTCHA validation. I have checked the code and cannot find a problem. The code is:
<?php require_once("webassist/form_validations/wavt_scripts_php.php"); ?>
<?php require_once("webassist/form_validations/wavt_validatedform_php.php"); ?>
if (isset($_POST["Submit"])) {
$WAFV_Redirect = "";
$_SESSION['WAVT_Questions_814_Errors'] = "";
if ($WAFV_Redirect == "") {
$WAFV_Redirect = $_SERVER["PHP_SELF"];
$WAFV_Errors = "";
$WAFV_Errors .= WAValidateLE($_SESSION['captcha_Security_Code_1'] . "",((isset($_POST["Security_Code_1"]))?$_POST["Security_Code_1"]:"") . "",true,1);
if ($WAFV_Errors != "") {
PostResult($WAFV_Redirect,$WAFV_Errors,"Questions_814");
<?php require_once("webassist/email/mail_php.php"); ?>
<?php require_once("webassist/email/mailformatting_php.php"); ?>
if (!isset($_SESSION))session_start();
if (($_SERVER["REQUEST_METHOD"] == "POST")) {
//WA Universal Email object="mail"
set_time_limit(0);
$EmailRef = "waue_Questions_2";
$BurstSize = 200;
$BurstTime = 1;
$WaitTime = 1;
$GoToPage = "ThankYou.htm";
$RecipArray = array();
$StartBurst = time();
$LoopCount = 0;
$TotalEmails = 0;
$RecipIndex = 0;
// build up recipients array
$CurIndex = sizeof($RecipArray);
$RecipArray[$CurIndex] = array();
$RecipArray[$CurIndex ][] = "nmyers6629@aol.com";
$TotalEmails += sizeof($RecipArray[$CurIndex]);
$RealWait = ($WaitTime<0.25)?0.25:($WaitTime+0.1);
$TimeTracker = Array();
$TotalBursts = floor($TotalEmails/$BurstSize);
$AfterBursts = $TotalEmails % $BurstSize;
$TimeRemaining = ($TotalBursts * $BurstTime) + ($AfterBursts*$RealWait);
if ($TimeRemaining < ($TotalEmails*$RealWait) ) {
$TimeRemaining = $TotalEmails*$RealWait;
$_SESSION[$EmailRef."_Total"] = $TotalEmails;
$_SESSION[$EmailRef."_Index"] = 0;
$_SESSION[$EmailRef."_Remaining"] = $TimeRemaining;
while ($RecipIndex < sizeof($RecipArray)) {
$EnteredValue = is_string($RecipArray[$RecipIndex][0]);
$CurIndex = 0;
while (($EnteredValue && $CurIndex < sizeof($RecipArray[$RecipIndex])) || (!$EnteredValue && $RecipArray[$RecipIndex][0])) {
$starttime = microtime_float();
if ($EnteredValue) {
$RecipientEmail = $RecipArray[$RecipIndex][$CurIndex];
} else {
$RecipientEmail = $RecipArray[$RecipIndex][0][$RecipArray[$RecipIndex][2]];
$EmailsRemaining = ($TotalEmails- $LoopCount);
$BurstsRemaining = ceil(($EmailsRemaining-$AfterBursts)/$BurstSize);
$IntoBurst = ($EmailsRemaining-$AfterBursts) % $BurstSize;
if ($AfterBursts<$EmailsRemaining) $IntoBurst = 0;
$TimeRemaining = ($BurstsRemaining * $BurstTime * 60) + ((($AfterBursts<$EmailsRemaining)?$AfterBursts:$EmailsRemaining)*$RealWait) - (($AfterBursts>$EmailsRemaining)?0:($IntoBurst*$RealWait));
if ($TimeRemaining < ($EmailsRemaining*$RealWait) ) {
$TimeRemaining = $EmailsRemaining*$RealWait;
$CurIndex ++;
$LoopCount ++;
session_commit();
session_start();
$_SESSION[$EmailRef."_Index"] = $LoopCount;
$_SESSION[$EmailRef."_Remaining"] = round($TimeRemaining);
session_commit();
wa_sleep($WaitTime);
include("webassist/email/waue_Questions_2.php");
$endtime = microtime_float();
$TimeTracker[] =$endtime - $starttime;
$RealWait = array_sum($TimeTracker)/sizeof($TimeTracker);
if ($LoopCount % $BurstSize == 0 && $CurIndex < sizeof($RecipArray[$RecipIndex])) {
$TimePassed = (time() - $StartBurst);
if ($TimePassed < ($BurstTime*60)) {
$WaitBurst = ($BurstTime*60) -$TimePassed;
wa_sleep($WaitBurst);
else {
$TimeRemaining = ($TotalEmails- $LoopCount)*$RealWait;
if (!$EnteredValue) {
$RecipArray[$RecipIndex][0] = mysql_fetch_assoc($RecipArray[$RecipIndex][1]);
$RecipIndex ++;
$_SESSION[$EmailRef."_Total"] = 0;
$_SESSION[$EmailRef."_Remaining"] = 0;
session_commit();
session_start();
if ($GoToPage!="") {
header("Location: ".$GoToPage);
Other than that, everything is functioning correctly. I created the form, added CAPTCHA, added server validation, then added UE4. Would you please let me know what the problem is?
Thanks!
Linda
please compress the original php code to a zip archive and attach the zip file so the see the entire page code in context.
lwade-bahr409715
Sorry for the delay. Attached is the zipped file. I appreciate your help.
anonymous
It looks like a problem on line 11 of your code:
It should look more like this:
$WAFV_Errors .= WAValidateLE((strtolower(isset($_POST["Security_Code_1"])?$_POST["Security_Code_1"]:"")) . "",((isset($_SESSION["captcha_Security_Code_1"]))?strtolower($_SESSION["captcha_Security_Code_1"]):"") . "",true,5);
Best regards,
Brian
lwade-bahr409715
Unfortunately, that didn't do it... it still sends with or without the code... even if an incorrect code is entered.
the server validation is set to trigger on a form element that does not exist.
your submit button is named "FormsButton1":
<input name="FormsButton1" type=SUBMIT class="submit" id="Forms Button1" value="Submit">
change the following code:
if (isset($_POST["FormsButton1"]))  {
lwade-bahr409715
Unfortunately, that didn't do it either. I have zipped and re-attached the file with both changes made.
