Complex form issue
Thread begun 6/20/2011 2:49 pm by Brad Lawryk | Last modified 2/11/2012 12:45 pm by Brad Lawryk | 2340 views | 4 replies |
Brad Lawryk
Complex form issue
I have a form where when submitted needs to edit two tables and insert into another. I can get it to work, but the problem is that every time the form page is opened it runs the insert.
Is there a way to set two triggers to an insert? Like for example If the button is pushed AND the record doesn't exist?
You cannot set two triggers for the insert through the wizard, you would need to modify the code after it is created to add the second condition to the trigger if statement.
for example the trigger code for any form post would look like this:
if($_SERVER["REQUEST_METHOD"] == "POST"){
to add a condition for the recordset being empty, change that to:
if($_SERVER["REQUEST_METHOD"] == "POST" && ($totalRows_RecordsetName == 0)){
Brad Lawryk
Thanks, I will give that a try.
Perhaps I can add that as a future product feature in an upcoming release to have multiple triggers. That would rock!
Brad Lawryk
That works great but is there a way to add a third trigger that checks if a value is greater than 24? I have:
if ($_SERVER["REQUEST_METHOD"] == "POST" && ($totalRows_rsCreditCheck == 0) && ($_POST['hours'] > 24))
But that doesn't seem to work.
Brad Lawryk
AH! Got it!
if ($_SERVER["REQUEST_METHOD"] == "POST" && ($totalRows_rsCreditCheck == 0) && ((isset($_POST["hours"]))?$_POST["hours"]:"") > 24)
Works great!
