Cross Browser issues
Thread begun 6/17/2011 10:53 am by Roland Rogers | Last modified 7/18/2011 6:55 am by Jason Byrnes | 5829 views | 7 replies |
Roland Rogers
This works great and addresses the main reason why I stopped using Spry to validate my form fields - the positioning of the message would often break the layout of the page.
This is very cool and work beautifully... in IE 8.
When tried on Safari (mac and pc) or Firefox (v3) it does not show the tooltip. Upon closer look it does show the very tip of the arrow of the tool tip at the top left of the page.
Any ideas why or what can be done to make it work across all browsers? See this link for the example.
contact.php
- Roland
This appears to be an issue with <table> based forms. If you wrap your spry spans with a relatively positioned div:
<div style="position:relative">
<span id="sprytextfield1" ...
</span>
</div>
That seems to correct the issue. We'll look into this more on our end and see if we can find a fix that doesn't require you to update your html.
kdavid379212
Just wondering if there has been a fix for this issue as I'm experiencing the exact same thing?
are you're forms based on a table?
see my previous reply to the original poster for a proposed fix.
kdavid379212
Thanks for the quick reply! Since I use Data Assist extensively, my forms are based on tables. I tried the fix, but had no luck on any browser other than IE8. Here's a simple file to illustrate the issue. Keep in mind that the bottom text input (outside the table) works perfectly on any browser.
you are adding the div artound the td tags:
<div id="test1" style="position:relative">
<td><span id="sprytextfield1">
<input type="text" name="textfield" id="textfield" />
<span class="textfieldRequiredMsg">A value is required.</span></span></td>
</div>
the div needs to be inside of the td tags:
<td><div id="test1" style="position:relative"><span id="sprytextfield1">
<span class="textfieldRequiredMsg">A value is required.</span></span></div></td>
kdavid379212
That fixed it. Thanks!
you're welcome.
