Unique database field inserted, but page is blank
Thread began 6/17/2011 10:34 am by Blikbrein | Last modified 7/11/2011 8:09 am by Jason Byrnes | 1901 views | 7 replies |
Blikbrein
I'm trying to add validation that searches whether a e-mail already exists when user is registering. When adding added code similar to the wizard's output, I end up with a blank page. I stripped down the server validations behaviour to only include the unique db field validation. I read that the Key value should be 0 from another post, but the SA wizard adds session variable values. Attached screenshot of wizard and page.
registration_requester.php.zip
i think line 14:
$WAFV_Errors .= WAValidateUnique("nrcahub",$nrcahub,$database_nrcahub,"Requesters","RequesterID","int","".((isset($_SESSION["RequesterID"]))?$_SESSION["RequesterID"]:"0")  ."","RequesterID","int","((isset($_POST[\"formEmail\"]))?$_POST[\"formEmail\"]:\"\")",true,1);
should be:
$WAFV_Errors .= WAValidateUnique("nrcahub",$nrcahub,$database_nrcahub,"Requesters","RequesterID","int","".((isset($_SESSION["RequesterID"]))?$_SESSION["RequesterID"]:"0")  ."","RequesterID","int","".((isset($_POST["formEmail"]))?$_POST["formEmail"]:"")."",true,1);
Blikbrein
Thanks for the help. Why is the '/' inserted into the code when I use validation toolkit? Is it a bug?
I'm still getting the blank page dispite changing the code. The email field in my db is indexed as unique and without the validation inserted I get the duplicate value error when posting the form with a already existing email inserted.
Rune Brynestad
I have exactly the same issue. Have you found a solution?
Regards
Rune
arteydiseno381654
Hello, I am also presenting the same problem
