60 second script timeout on host
Thread begun 6/16/2011 12:35 pm by CraigR | Last modified 6/17/2011 10:50 am by Lon Winters | 6142 views | 10 replies |
CraigRBeta Tester
I was having problems with sending a bulk email stopping after about 70 messages
Since I reduced the wait time to 0.25, it works on my host, but when I updated the client site, the process still stops after about 80 messages.
Is this a timeout problem ?
I notice in the code, if the wait time is < 0.25, it is set to 0.25.
How would UE cope with 500 or 1000 mailings ?
I am only looking at about 100, but it is failing for the client 50% of the time
Kumel
i had da same prob.. I think u must make the max_execution_time value to 0 (zero)
there has to be at least a .25 second pause between sending the messages to the smtp server or the smtp server will terminate the connection.
It could be a number of things causing the emails to stop at 80.
It could be a limitation on the server that only allows 80 messages to be sent in a given time frame.
first thing i would try is to add the following code at line 1:
<?php set_time_limit(0); ?>
if you're still having a problem, contact the host to see what limits are in place for sending emails through the smtp server. they may on y allow a certain number in a day, or a certain number every hour.
CraigRBeta Tester
On my own hosting server, the script timeout is 60 seconds.
They allow up to 200 emails per hour, and 2000 per day.
At 1 second intervals between messages, the maximum I could send was around 70 messages.
When I reduced the interval, I can send over 200, but I can then reload the page and send another 200.
So I don't think the sending limit is the problem, more the fact that the script is timing out,
I think with my client, the shared hosing may be taking longer to respond during busy times, so with a 60 second timeout, could this shared hosting be a factor ?
In the meantime, I will try your sugggestion.
CraigRBeta Tester
No luck
I changed line 1 as Jason suggested, I still get the error after about 1 minute.
I checked php.ini to ensure it is not in safe mode, also max execution time is set to 300 in php.ini
I raised a ticket with my host and the reply is as follows...
  All PHP/CGI/Perl scripts are limited to a 60 seconds run time. If your script does not complete during that time, it will be killed
I find this really frustrating, because I can't test it except in a live environment.
Overall, even if I had 1000 emails to send, would I have to wait for the script to process 3-4 emails a second and wait 5 minutes ?
Is anyone using UE for large mailing lists ? and how are they achieving it ?
this means that your host has imposed a 60 second time limit regardless of how you set the php.ini file or the set_time_limit setting.
Universal Email will try to adjust that time out setting as well, when sending large email lists, but if the server does not allow for the timeout setting to be changed, then there is not much that can be done for it.
Universal Email wont be able to process large mailing lists on this host, due to the time limit they are imposing.
CraigRBeta Tester
Just a final thing on this.
On my host, with a script timeout of 60 seconds, i can squeeze out nearly 200 emails before failure
I can just about live with this limit, but my client says that sometimes only 15 or 20 emails get through on their host.
They are understandable frustrated and are considering setting up with another hosting provider, but I am reluctant to suggest mine, (fatcow) who are generally excellent, but obviously restrictive.
I just checked their php ini with their current hosting provider and execution time is set to 30 seconds - i will take a look at setting the time limit on page.
With shared hosting, is this exacerbated ?
shared hosting is always more restrictive then dedicated hosting. It could certainly be a contributing factor to the problem.
CraigRBeta Tester
sorry, to clarify, can high traffic on a shared hosting site effectively reduce this timeout as the server has less resources to process the script ?
I suppose that is possible, but high traffic really should not effect a script timing out.
