can't upload images
when I try to upload images I get this error message...
This file uploader is disabled. Please check the "editor/filemanager/connectors/php/config.php" file
what should I be looking for?
Edit the HTML Editor instance applied to your page.
Next to the preset list, Click the edit icon to edit the preset settings, make sure to check the Allow File Upload option.
Hi Jason
what preset list? I've got iRite 1.0.3
ahhh, for iRite 1.0.3, see the "Allowing image uploading with the iRite text editor" Tutorial in the archived documentation section of the HTML Editor support page:
html-editor/
this document shows how to change from php configuration to either .asp or .cfm, I'm using .php
however, the "Adding an Insert Image feature to your iRite toolbar" section details how to do it,
thanks for pointing me in the right direction
