Site Hacked - Security Assist
Thread begun 6/11/2011 4:28 pm by dlovas275157 | Last modified 6/17/2011 3:02 am by iansheldon422428 | 6747 views | 16 replies |
dlovas275157
I have built a custom cms for a website with DataAssist and other extensions secured with Security Assist. Yesterday, my site was hacked in the following ways:
1. Hacker uploaded images - I assume via backend insert/update forms.
2. Added text - again i assume using insert/update form.
They could have done a lot more damage, but luckily did not.
All forms are password protected via security assist, so I need to understand how/why this happened.
Could someone from support please open a ticket, at which time I can provide urls and access to my site for you to take a quick look.
I was reading another thread here regarding setting up read-only database users for front end pages, but I really would like someone to look at me site and let me know if the see any holes and if this is sql injection:
showthread.php?t=7587&highlight=hack&page=2
Thanks.
-Dan
Using
Mac OSX
DW CS5
DataAssist 2.0.8
SecurityAssist 1.1.9
tom92909Beta Tester
Do you have your administrative back end also secured behind a protected directory on the server?
I run Linux on all my sites and I create a very obscure directory name and I place all my admin tools behind the protected directory in addition to placing Security Assist on those pages. It does create (2) levels of security, but the admin pages need that extra level.
My gut tells me your might be a victim of a Keylogger (malware) attack.
iansheldon422428
Also.... Are you hiding your admin directories from the search engines / spiders / robots with a correctly configured robots.txt file?
Cheers
Ian
tom92909Beta Tester
yes I place all of those directories in my robots.txt file as well.
tom92909Beta Tester
Sample robots.txt
# Keeps Googlebot out of private files
User-agent: Googlebot
Disallow: /_Admin
Disallow: /WA_DataAssist/
Disallow: /WA_eCart/
Disallow: /WA_Globals/
Disallow: /webassist/
Disallow: /Connections/
It would be interesting to see the insert and update pages they were able to access. Perhaps you don't have the security code properly applied.
Another possibility is that the person had a username and password and was able to log in. Security Assist will help make it so that login is required, but if someone has login information it won't help.
Sometimes a SQL injection hole on the site front end can allow someone to get username and password information they can use to log in on the back end... but how would they even find your admin section?
If you have SecurityAssist properly applied, then the only way to get to those pages is to log in. So you should probably be trying to figure out how they got that login information and I'd say a sql injection hole is the most likely place.
dlovas275157
Ray,
I double-checked all the pages for security, and all appear to be setup with Security Assist properly. I have used Security assist on many sites before for years and never had a problem.
You mentioned a SQL Injection Hole. How could I tell if there is a SQL Injection Hole on the front end?
superpac250441
I am watching this thread with serious concerned. It seems that security assist cannot be used simply as a plug 'n play, more needs to be done to ensure security.
If this is indeed the case, please can someone provide a full list of what other measures must be carried out to ensure rock-solid security.
Miguel
To check the holes on your site check how you call your ids and try to do injections on any contact fiorm you got for example
