FedEx Quotes and Checkout holding information
Thread began 6/09/2011 11:33 am by eric284736 | Last modified 6/10/2011 8:20 am by Jason Byrnes | 1590 views | 5 replies |
eric284736
I am trying to setup Fed Ex shipping and I have the Account # and Meter #, but it does not display a shipping quote from FedEx. The confirm page is attached as well as the FedEx php page.
Also on the checkout page I am trying to bind the fields to retain the information entered, but it does not work.
The First Name field is binding to the checkout form session and the other fields were originally binded to the checkout form.
What am I doing wrong?
thx
Eric
New Folder.zip
in the fedex server behavior, you have provided a ship to state of "none" and no zip code:
$Shipping_Parameters["ShiptoState"] = "none";
$Shipping_Parameters["ShiptoZip"] = "";
fed ex can look up a shipping rate to "none", yu need to provide a valid ship to State or zip.
the only set session code I see on the confirm page is lines 9 - 32:
if (!session_id()) session_start();
if(
$_SERVER["REQUEST_METHOD"] == "POST")     {
$_SESSION["eCartCheckoutForm_state_province"] = "".((isset($_POST["state_province"]))?$_POST["state_province"]:"")  ."";
if(
$_SESSION["eCartCheckoutForm_country"] = "".((isset($_POST["country"]))?$_POST["country"]:"")  ."";
if(
$_SESSION["eCartCheckoutForm_shipping_state_province"] = "".((isset($_POST["shipping_state_province"]))?$_POST["shipping_state_province"]:"")  ."";
if(
$_SESSION["eCartCheckoutForm_shipping_country"] = "".((isset($_POST["shipping_country"]))?$_POST["shipping_country"]:"")  ."";
the code to set the other sessions is missing from this page.
eric284736
Thanks Jason!
I am just moving over to php from asp, so I am trying to get a handle on everything.
You might know the answer to this also:
I have the OrderDate in the database set as timestamp, but on a test order the date came in as 2006-09-11 00:00:00
Is that something I can correct?
thx
Eric
the time stamp format is yyyy-mm-dd hh:mm:ss
in the store order summary you are using the php data command to pass the date suing the mm/dd/yy format instead
date("m/d/y")
change that to pass the correct format:
date("Y-m-d h:m:s")
eric284736
Excellent! Thank you Jason!!!
you're welcome.
