Product not adding to Cart
Thread begun 7/06/2009 8:21 am by bjgarner241692 | Last modified 10/09/2009 1:29 pm by Ray Borduin | 6976 views | 12 replies |
bjgarner241692
I'm stumped.
I am moving a clients site from another server to my own.
I exported the MySQL db to XML and imported it into the new server db.
I took an exact copy of all files and uploaded it.
I edited the connection string to use the new information.
Product displays fine on listings page.
Product displays fine on details page.
Admin pages work. I can add, remove, update product no problem.
When I click Add to Cart, I am redirected to the correct cart page but it shows. The cart is empty.
I've replaced the Add to Cart functions.
I've replaced the Cart page.
Nothing changes. No error, just an empty cart.
Both servers support the same versions of PHP (5.)
Anyone have an idea of where to start?
Try adding:
session_commit();
before the location("header: "...
function call which redirects. Sometimes the server has a bug that will prevent sessions from being set unless committed explicitly, which isn't usualy necessary.
bjgarner241692
Thanks, but I cannot locate "header: " in any document on the site.
Also, my server has several WAeCart's running just fine in php and asp.
I'd like to try this, but I do not see where to insert the instruction.
On your add to cart page...
You should be able to see the redirect code right before the open <html> tag.
That is where you would add it... sorry my dyslexia... it should be:
header("location...
bjgarner241692
OK, I found this on each of the cart related pages:
// WA eCart Redirect
if ($eCart1->redirStr != "") {
header("Location: ".$eCart1->redirStr);
I changed it to this on the ordering page and it now works.
session_commit();
I have left the cart, checkout etc. pages as they were.
I am curious how this could happen as I have other sites on the same server that do not have session_commit(); in them.
There is probably another error on the page causing the problem. I'd have to debug it to see... maybe a blank line or space in the code somewhere above the redirect.
bjgarner241692
There was a blank line earlier in the document that seems to have been the problem.
That would not have been an issue in ASP. I'll have to watch for that.
bjgarner241692
I had the same problem again.
Will this be addressed in a future release?
Where are the lines in question. If you report errors with line numbers they will be corrected. The only ones we wouldn't correct would be ones we haven't found.
bjgarner241692
//WA eCart Include
require_once("WA_eCart/eCart1_PHP.php");
$eCart1->GetContent();
<?php require_once('Connections/zeoconn.php'); ?>
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
$param_prod = "-1";
if (isset($_GET["ID"])) {
$param_prod = (get_magic_quotes_gpc()) ? $_GET["ID"] : addslashes($_GET["ID"]);
mysql_select_db($database_zeoconn, $zeoconn);
$query_prod = sprintf("SELECT * FROM store_prods WHERE ID = %s", GetSQLValueString($param_prod, "int"));
$prod = mysql_query($query_prod, $zeoconn) or die(mysql_error());
$row_prod = mysql_fetch_assoc($prod);
$totalRows_prod = mysql_num_rows($prod);
// WA eCart AddToCart
if (isset($_POST["eCart1_1_ATC"]) || isset($_POST["eCart1_1_ATC_x"])) {
$ATC_itemID = $_POST["eCart1_1_ID_Add"];
$ATC_AddIfIn = 0;
$ATC_RedirectAfter = "cart.php";
$ATC_RedirectIfIn = "cart.php";
if (isset($totalRows_prod) && $totalRows_prod > 0) {
$row_prod = WAEC_findRecordMySQL($prod, "ID", $ATC_itemID);
if ($row_prod) {
$ATC_itemName = "".$row_prod['Name'] ."";// column binding
$ATC_itemDescription = "".$row_prod['ProdSize'] ."";// column binding
$ATC_itemWeight = floatval("0");// column binding
$ATC_itemQuantity = "".$_POST["eCart1_1_Quantity_Add"] ."";// column binding
$ATC_itemPrice = floatval("".$row_prod['ProdPrice'] ."");// column binding
mysql_data_seek($prod, 0);
$ATC_itemQuantity = floatval($ATC_itemQuantity);
if (is_numeric($ATC_itemQuantity) && $ATC_itemQuantity != 0) {
$eCart1->AddToCart($ATC_AddIfIn, $ATC_RedirectIfIn, $ATC_itemID, $ATC_itemName, $ATC_itemDescription, $ATC_itemWeight, $ATC_itemQuantity, $ATC_itemPrice);
if ($ATC_RedirectAfter != "" && $eCart1->redirStr == "") {
$eCart1->redirStr = $ATC_RedirectAfter;
if (isset($_SERVER['QUERY_STRING']) && $_SERVER['QUERY_STRING'] != "") {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF']."?".$_SERVER['QUERY_STRING'];
else {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF'];
session_commit();
This would not work until I added session_commit(); just after // WA eCart Redirect
All of the code is straight out of the WA tools.
