Multiple Add to Cart Problems...
Thread begun 7/06/2009 8:20 am by vito374252 | Last modified 7/06/2009 11:50 am by vito374252 | 9843 views | 20 replies |
vito374252
Hi
I'm trying to add multiple items to my cart, but nothing happens when I hit the add to cart button on the site. Here is the URL: counsellors_Results.php
Here is the filter:
//WA Database Search (Copyright 2005, WebAssist.com)
//Recordset: counsellorsAddSelected;
//Searchpage: ;
//Form: ;
$WADbSearch2_DefaultWhere = "AND counsellorID = 0";
if (isset($_POST["AddToCartBtn_x"])) {
$WADbSearch2 = new FilterDef;
$WADbSearch2->initializeQueryBuilder("MYSQL","1");
//keyword array declarations
//comparison list additions
$WADbSearch2->addComparisonFromList("counsellorID","ATCCheck","AND","=",1);
//save the query in a session variable
if (1 == 1) {
$_SESSION["WADbSearch2_counsellors_Results"]=$WADbSearch2->whereClause;
else {
//get the filter definition from a session variable
if (1 == 1) {
if (isset($_SESSION["WADbSearch2_counsellors_Results"]) && $_SESSION["WADbSearch2_counsellors_Results"] != "") {
$WADbSearch2->whereClause = $_SESSION["WADbSearch2_counsellors_Results"];
else {
$WADbSearch2->whereClause = $WADbSearch2_DefaultWhere;
else {
$WADbSearch2->whereClause = str_replace("\\''", "''", $WADbSearch2->whereClause);
$WADbSearch2whereClause = '';
Here is the form:
<form method="post" name="add_to_cart" id="add_to_cart">
<table width="800">
<tr>
<td width="638">Click the <strong>Book Personal Assessment Now</strong> button to add all selected counsellors to the shopping cart.</td>
<td width="150"><input type="image" name="AddToCartBtn" id="AddToCartBtn" src="images/counselling/book-pa-now.gif" /></td>
</tr>
</table>
<table class="WADAResultsTable" border="0" cellpadding="0" cellspacing="0">
<tr>
<th class="WADAResultsTableHeader">Counsellor Name:</th>
<th class="WADAResultsTableHeader">Town:</th>
<th class="WADAResultsTableHeader">County/Country:</th>
<th class="WADAResultsTableHeader">Counsellor Bio:</th>
<th class="WADAResultsTableHeader">Professional Body:</th>
<th class="WADAResultsTableHeader">Ongoing Fees/Session:</th>
<th class="WADAResultsTableHeader">Type of Therapy:</th>
</tr>
<?php do { ?>
<tr class="<?php echo $WARRT_AltClass1->getClass(true); ?>">
<td class="WADAResultsTableCell"><?php echo($row_WADAcounsellors['first_name']); ?>
<input name="ATCCheck[]" id="ATCCheck[]" type="checkbox" value="<?php echo $row_counsellorsAddSelected['counsellorID']; ?>" />
<span class="WADAResultsTableCellname"> Include this counsellor in your booking.</span></td>
<td class="WADAResultsTableCell"><?php echo($row_WADAcounsellors['town']); ?></td>
<td class="WADAResultsTableCell"><?php echo $row_WADAcounsellors['county_country']; ?></td>
<td class="WADAResultsTableCell"><?php echo($row_WADAcounsellors['bio']); ?></td>
<td class="WADAResultsTableCell"><?php echo($row_WADAcounsellors['professional_body']); ?></td>
<td class="WADAResultsTableCell"><?php echo($row_WADAcounsellors['fees_session']); ?></td>
<td class="WADAResultsTableCell"><?php echo($row_WADAcounsellors['type_of_therapy']); ?></td>
</tr>
<?php } while ($row_WADAcounsellors = mysql_fetch_assoc($WADAcounsellors)); ?>
</table>
</form>
That either means your recordset is not filtered correctly, or it means your add to cart is not set up correctly.
Does the value of <?php echo($WADbSearch2->whereClause); ?> look correct?
vito374252
The value is AND ((counsellorID = 0))
That seems wrong, so the problem is in creating the correct search query based on the checkboxes. If you view the source code on the completed page, do the checkboxes have the correct values? Which did you check when you got that where clause returned?
vito374252
Same thing, source code says AND ((counsellorID = 0)), and that doesn't matter which checkbox I check
Do you have a url where I can view the page?
vito374252
yeah, ...rs_Results.php. Do you need more code from my side?
Also, do you think that the fact that theis page is the result of a search from another page is causing a problem?
Possibly...if you are overwriting it or something. That url doesn't seem to work it looks like some of the characters were replaced so I can't browse it.
Ok I was able to veiw the page.
The problem is with your checkboxes... they look like:
<input name="ATCCheck[]" id="ATCCheck[]" type="checkbox" value="" />
notice the value is blank. That is why it isn't working... maybe a bad recordset column reference.
vito374252
I've attached a .zip file with the search page and the results page
