No checkout_success after confirm
Thread begun 6/08/2011 12:38 pm by m.finelli420407 | Last modified 11/17/2011 6:59 am by Jason Byrnes | 4928 views | 12 replies |
m.finelli420407
Hello there,
I've tried this matter a lot of times, but I still get the same result. The story so far:
I've created a cart and I have all the stuff in place (cart display, confirm, checkout, checkout success pages...).
I've chosen to have a "no payment gateway" because my client wants to receive the order and confirm it after by phone.
I passed all the wizard's steps, configurate the email (I'm testing it on my Mac in locale, so I added my own email address and the SMTP that belongs to my account), but when I complete all the buying passages - add an item to the cart, enter my data in the checkout page - arrived at the confirm page when I hit "Confirm order"... nothing happens.
No checkout success page, no inserting of the order in the database...
I've attached the php script of my confirm.php page. I'm using Cart 5
Any suggestion?
Thanks for your help.
Most likely there is a php error occurring but error reporting is turned off.
add the following code at line 1 to turn on error reporting.
error_reporting
(E_ALL);
m.finelli420407
Hi Jason, thanks for the reply.
I've copied the php code for revealing errors and I've got this message:
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /Applications/MAMP/htdocs/Fontana2/confirm.php:5) in /Applications/MAMP/htdocs/Fontana2/WA_eCart/WA_eCart_Definition_PHP.php on line 465
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /Applications/MAMP/htdocs/Fontana2/confirm.php:5) in /Applications/MAMP/htdocs/Fontana2/WA_eCart/WA_eCart_Definition_PHP.php on line 465
Warning: Cannot modify header information - headers already sent by (output started at /Applications/MAMP/htdocs/Fontana2/confirm.php:5) in /Applications/MAMP/htdocs/Fontana2/confirm.php on line 211
So, for you to look at, I'm attaching the confirm zip file with the php errors turned on and the WA_eCart_Definition_PHP.php.
Looking for your reply.
Thanks again,
Michele
that error is being caused by a trailing space after the closing php block on line 4:
see the following thread for more details on the headers already sent error and how to troubleshoot it:
showthread.php?t=19285
maybe try changing the trigger for the store order summary and store or details behaviors to use the Button submit _Order pressed trigger instead of current page submit.
m.finelli420407
Hello Jason,
clearing the trailing space and changing the triggers worked... but after pressing confirm, now I receive this message:
Unknown column 'fefa08f37f9004c2422074484c347e0b' in 'where clause'
Help is needed!
Thanks in advance
Michele
m.finelli420407
Solved!
My fault. I've attached the Session ID to the Order ID and the value of the Order ID in the db was INT(11)...
Thanks Jason for solving the matter!
Bye!
glad to hear it is working.
MikeyT
Jason, I was hoping you could take a look at the attached confirm.php page. I've included error reporting at line 1, but nothing is showing up. I can't seem to get to the checkout_success page. I'm just getting a spinning processing icon in the browser. I went through the checkout wizard following the manual and didn't do anything out of the ordinary. My cart is not using a payment gateway. Thanks for any help.
the only thing happening on [pressing confirm is sending the email.
in the email settings, what did you use for the smtp server?
who is your host?
MikeyT
That's strange. I swore I filled in that info in the wizard. I just added it again and am still having the same issue. Attached is a new file with the smtp and port info included. Sorry to bug you about this.
