Cannot access page even though logged in
Thread begun 6/08/2011 7:29 am by A Sound Design | Last modified 6/30/2011 11:02 am by Jason Byrnes | 5632 views | 12 replies |
A Sound Design
I am using SA 2 and have created login, registration pages etc. using the wizard.
I can successfully register and login but when I try to access a page that is protected using the Access Pages Manager I am continually redirected to the Access Denied page I have created. In the MySQL table I have set a field UserLevel as Int (11). I manually assign a user access level to each registered user, where administrators are level 3. In the SA Secure Page settings for each page I have it as in the attached screenshot. I cannot see why this does not work based upon this rule setting.
The code at the top of the page is
<?php require_once( "../webassist/security_assist/helper_php.php" ); ?>
if (!WA_Auth_RulePasses("Administrator")){
WA_Auth_RestrictAccess("access_denied.php");
//initialize the session
if (!isset($_SESSION)) {
session_start();
// ** Logout the current user. **
$logoutAction $_SERVER['PHP_SELF']."?doLogout=true";
if ((isset(
$_SERVER['QUERY_STRING'])) && ($_SERVER['QUERY_STRING'] != "")){
$logoutAction .="&"htmlentities($_SERVER['QUERY_STRING']);
if ((isset(
$_GET['doLogout'])) &&($_GET['doLogout']=="true")){
//to fully log out a visitor we need to clear the session varialbles
$_SESSION['MM_Username'] = NULL;
$_SESSION['MM_UserGroup'] = NULL;
$_SESSION['PrevUrl'] = NULL;
  unset(
$_SESSION['MM_Username']);
  unset(
$_SESSION['MM_UserGroup']);
  unset(
$_SESSION['PrevUrl']);
$logoutGoTo "logout.php";
  if (
$logoutGoTo) {
header("Location: $logoutGoTo");
    exit;
Thanks in advance. I'm now way behind on schedule for this project so any help appreciated.
Does the login page set the UserLevel Session?
Double click the Authenticate User server behavior on the login page and go to the third page, make sure the UserLevel column is added to the list of sessions to set.
just to double check what sessions are being set, add the following code to the access denied page:
</pre><?php var_dump($_SESSION); ?></pre>
A Sound Design
The output from the above code simply says 'NULL'. I've attached the code for the login page.
that make me think the server is not setting session variables properly.
use the session test page from the following thread to test the servers session management:
showpost.php?p=23826&postcount=2
if the session test fails, you will need to contact the host to have them correct the problem, it is most likely a bad setting for the session.save_path in the php.ini
A Sound Design
Uploaded that file and the server passed the test. Btw, I'm using XAMPP on local testing server.
strange,
try changing:
</pre><?php @session_start(); var_dump($_SESSION); ?></pre>
A Sound Design
Outputs
array(3) { ["WAENCRYPTEDRETURNUSED"]=> bool(false) ["WAENCRYPTEDRETURNSUCCESS"]=> bool(false) ["test"]=> string(4) "test" }
A Sound Design
Thanks, but I had to uninstall version 2 and go back to version 1.1.9 for now at least so that I can get the job finished. Still took a bit of fiddling but at least I can create a registration page, a login page and get pages secured.
I have had nothing but problems with version 2 since installing it and have spent hours of my time, and money on the upgrade unless I can get it to work. I'll come back to this once I have this project finished as that is the immediate priority.
ok, if you run into problems again with version 2, update the ticket that was created and we will look into the cause of the issue with you over the phone.
