populate form with values, what do i use???
Thread begun 6/08/2011 3:17 am by Base5 Designs | Last modified 6/09/2011 6:53 am by Jason Byrnes | 2192 views | 3 replies |
Base5 Designs
hi i have a update form on a page
the form has spry validation and one field has spry and a server validation to check the record is unique.
if i set the default value of the form field to the value from the recordset filtered by the id the correct value shows initially, but if the server validation fails, all the form fields are empty.
so i change the default values to use the values from WAValidatedEntries collection
now when the form initally loads they are empty.
my question is this:
how do i poulate the form with the initial values currently stored in the db when the form is first loaded and then if the validation fails populate the form with the validated entries.
i hope you understand the problem and can gibe me the answer, am sure its something very simple, but the documentation is so basic with very little detaild explanation of anything, and there are so many diffirent collections in the bindings, its not really clear what i should be using.
this takes a little bit of hand coding to accomplish.
first, make sure that the server validations server behaivor is set to pass a querystring variable on failure:
pagename.php?valid=false
we can use the valid query string variable to tell the form whether to use the validated entries collection or the recordset collection.
you recordset binding code will look similar to this:
<?php echo $row_recordsetName['firstname']; ?>
the validated entries binding code will look similar to:
<?php echo(ValidatedField("confirm","firstname")) ?>
we can put these together using a ternary expression like this:
<?php echo((isset($_GET['valid']))?(ValidatedField("confirm","firstname")):$row_recordsetName['firstname']); ?>
Base5 Designs
Thanks working perfectly, am starting too really get the hang of things, takes a while to learn but am enjoying using much more than the old interact/addt stuff.
one thing i would like to suguest is in your documentation, if the various collections in the bindings were explained in more detail not just in general but for each item in the collection, what it contains etc.
the documentation contains good guides, but is a walkthrough once you stray off that path, its very difficult to know what each of the various items needed to fill in are for, as there is very little expalnation too the possible values that could be inserted.
maybe there is something that contains this information already but i have not found it on your site.
thanks again for your time and support.
any documentation requests should be sent to the documentation team using the feedback form:
feedback.php?type=docs
