check unique entry on update
Thread begun 6/07/2011 3:33 pm by Base5 Designs | Last modified 6/08/2011 2:41 am by Base5 Designs | 1226 views | 1 replies |
Base5 Designs
hi there,
have managed to get the check unique entry on insert working fine by using a recordset and checking if there is an existing value and validating against the recordcount.
now my problem is with the update, obviously as there exists a record (the one i am updating)
it returns 1 as the record count so wont validate.
so how do i check this on an update?
Base5 Designs
I managed to sort this out.
for anyone else looking for an anser i did the following.
I followed the same technique as checking on insert, creating a recordset filtered by the new value i wanted to insert and using the server validations to check if the recordset was empty.
the teqnique for update is the same, although as well as filtering the table to insert into by the value you want to insert also add to the where clause the following:
AND myColulmnID != myID
(mycolulmnID is the unique key for the record and myID should be set to $_POST["WADAUpdateRecordID"])
this way we check all records for the new value, except the current record we arew trying to update.
the full recordset code would look something like this:
$colname_slugcheck = "-1";
if (isset($_POST['slug_dct'])) {
$colname_slugcheck = (get_magic_quotes_gpc()) ? $_POST['slug_dct'] : addslashes($_POST['slug_dct']);
$myid_slugcheck = "-1";
if (isset($_POST["WADAUpdateRecordID"])) {
$myid_slugcheck = (get_magic_quotes_gpc()) ? $_POST["WADAUpdateRecordID"] : addslashes($_POST["WADAUpdateRecordID"]);
mysql_select_db($database_albionwines, $albionwines);
$query_slugcheck = sprintf("SELECT id_dct, slug_dct FROM drinkcats_dct WHERE slug_dct = %s and id_dct != %s", GetSQLValueString($colname_slugcheck, "text"),GetSQLValueString($myid_slugcheck, "int"));
$slugcheck = mysql_query($query_slugcheck, $albionwines) or die(mysql_error());
$row_slugcheck = mysql_fetch_assoc($slugcheck);
$totalRows_slugcheck = mysql_num_rows($slugcheck);?>
