HELP! - Applying Login to your Checkout Page
Thread begun 6/07/2011 12:13 pm by hbibizadeh396670 | Last modified 6/08/2011 12:00 pm by Jason Byrnes | 7218 views | 11 replies |
hbibizadeh396670
I am using PayPal express checkout.
I need to make sure that the user is logged in before they are able to proceed to checkout.
I followed the PDF file on eCart Support page, however I does not work.
I am not sure what is going wrong but I get two errors.
When a user clicks add to cart, I am redirected to a page with this error: The webpage cannot be found
However I do not think that it is a problem with the link, as when I lunch the Cart Page directly I get the same error page.
Links:
Results.php
Direct link to Cart:
Cart.php
Hope you can help
the access restriction you applied to the cart page is set to redirect to the login page at:
http://ashperfectimage.com/UserRegistrationSystem/LogIn.php
but the correct address for the login page is:
http://ashperfectimage.com/Siteezy_eCart2/UserRegistrationSystem/LogIn.php
hbibizadeh396670
thank you, it works
hbibizadeh396670
Unfortunately I have realised that this method is not sufficient for PayPal Express Checkout which I am using.
The problem is:
With PayPal Express checkout the user is directed to log in when they have returned from PayPal. This is because the confirm page directs them.
Although this would work if the customer is already registered with my website, in the situation when they are not, they would have to leave the transaction process, in order to register and then have to restart the payment process, which is highly unprofessional.
What I need to do is create some sort of trigger, when the user click the checkout button on the cart page, it immediately should check to see if the user is logged in, in which case, the user is either directed to login/register, or PayPal to proceed with payment.
Hope you can help,
Thank you in advance
Use the security assist Show Region Behavior to, You could also show a link to the login page if they are not loged in.
hbibizadeh396670
Ok, this would work.
However I have a question. If I show a login link to the login page, is there a way of directing them back to the cart page after login. Like the way it works if you restrict access to a page.
Otherwise, after logging in the user would go to their control panel, which could confuse some people.
Thank you.
create the login link with an accesscheck querystring variable that passes the current page, the login will use the access check page as the success redirect if it exists:
<a href="login.php?accesscheck=<?php echo(urlencode($_SERVER['PHP_SELF'])); ?>">Log in</a>
hbibizadeh396670
Ok,
That works for existing customers who can simply login.
However, I am not sure how new customers can register without losing the ability to be directed back to the cart.
The problem is that if a new customer needs to register they are directed to the register page. From their they proceed to login.
I this stage, they would go back to the control panel.
This creates a problem as I still think it would confuse some customers.
Is there a way of allowing a customer to register and login as a new customer, and be directed to the cart page?
Thank you.
this is a little trickier.
make sure the register link passes the same qs variable:
<a href="register.php?accesscheck=<?php echo(urlencode($_SERVER['PHP_SELF'])); ?>">Log in</a>
on the registration page, make sure the forms action is set to pass any qs variables passed in:
 action="<?php echo $_SERVER["PHP_SELF"]; ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".$_SERVER["QUERY_STRING"]:""?>"
and that the redirect to the login page also passes the query string variables, in the insert record behavior, set the redirect to:
login.php<?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".$_SERVER["QUERY_STRING"]:""?>
hbibizadeh396670
ok Ill try it
