Include file not being found
Thread begun 6/07/2011 6:09 am by Base5 Designs | Last modified 6/07/2011 12:27 pm by Jason Byrnes | 1926 views | 1 replies |
Base5 Designs
hi there
am trying to use the framework with an admin area on my site.
i have created all the admin pages and they are working as their own entitys.
i have created a framework from my admin template.
when i launch the page in the browser i get the following errors:
Warning: require_once(../../Connections/albionwines.php) [function.require-once]: failed to open stream: No such file or directory in D:\inetpub\vhosts\albionwineshippers.co.uk\httpdocs\admin\countries\index.php on line 1
Call Stack
# Time Memory Function Location
1 0.0009 74760 {main}( ) ..\index.php:0
2 0.0065 406432 require( 'D:\inetpub\vhosts\albionwineshippers.co.uk\httpdocs\admin\countries\index.php' ) ..\index.php:11
( ! ) Fatal error: require_once() [function.require]: Failed opening required '../../Connections/albionwines.php' (include_path='.;D:\Parallels\Plesk\Additional\PleskPHP5\pear;./includes;./pear') in D:\inetpub\vhosts\albionwineshippers.co.uk\httpdocs\admin\countries\index.php on line 1
Call Stack
i have been trying for half the day now to wor out this problem.
i have loged onto the server and checed the files are where they should be and they are.
the other admin pages that use the include_once function (for the connection strings are woring fine), so i am certain it is not an error with the php installation.
if i put that same connection string code in the index.php(framewor page)
that also generates a Fatal error: require_once() [function.require]: Failed opening required
error so it seems to be a problem with the framework stuff.
i have searcha ll the threads on the forums and tried replacing the framewor.php file from this thread ( showthread.php?t=19490 )
that has not fixed the problem either.
i have included a zip file with a dreamweaver 5 .ste file so you can connect to my webserver directly should you need to troubleshoot the problem live, also included in the zip are the ftp details and site info.
hope you can help me get to the root of this problem.
thank you for your time.
