Update/Delete/Insert in one Form?
Thread begun 6/07/2011 2:52 am by info4753 | Last modified 6/08/2011 8:12 am by info4753 | 4664 views | 10 replies |
info4753
Is it possible to create with FB a single form for insert/update/delete functions? Or do I have to create 3 pages?
you can add insert update and delete forms to the same page, just make sure that each form uses a unique name for the submit button.
you will need to use the submit buttons as the trigger for the insert update and delete behaviors.
info4753
This post has been deleted.
info4753
Do I have to insert 3 forms?
yes, you need a seperate form for each action.
info4753
So the customer sees 3 forms?
By the way I try to built a form with FB and added the update server behaviour from data assist but filtering the recordset with URL-Parameter doesn't work. What do I wrong?
I have a list of recordsets with a link like form.php?ID=3 and on the edit page a form to edit its data. But filtering via value <?php echo $_GET['ID']; ?> is not working.
yes, the customer would see 3 form.
Send a copy of you page so i can see the code in order to see what may be wrong.
info4753
Thanks Jason. This drives me crazy ...
your recordset code does not use the ID querystring variable, it uses the FIRMID querystring variable:
$colname_rsFirmen = "-1";
if (isset($_GET['FIRMID'])) {
  $colname_rsFirmen = (get_magic_quotes_gpc()) ? $_GET['FIRMID'] : addslashes($_GET['FIRMID']);
mysql_select_db($database_HPharm, $HPharm);
$query_rsFirmen = sprintf("SELECT * FROM firmen WHERE FIRMID = %s", GetSQLValueString($colname_rsFirmen, "int"));
$rsFirmen = mysql_query($query_rsFirmen, $HPharm) or die(mysql_error());
$row_rsFirmen = mysql_fetch_assoc($rsFirmen);
$totalRows_rsFirmen = mysql_num_rows($rsFirmen);
your link:
form.php?ID=3
should be:
form.php?FIRMID=3
info4753
Sorry for that, with ID I've mentioned a basic example, I DO pass FIRMID as URL-parameter from the list to the form page and filter it for the recordset (works) and update behaviour (deosn't work).
