Multiple Record Insert...
Thread begun 6/06/2011 1:23 pm by Jim E D | Last modified 6/07/2011 8:50 am by Jason Byrnes | 1882 views | 3 replies |
Jim E D
I need to link in a number of "categories" to my main table.
In the attached page I've just added my second single recordset (sponsor) to the file. The first two insert fine, but I get no inserts for the Sponsor.
What am I missing?
Thanks again
the code at line 46 - 103 has the sponsor being inserted before the marker is created
// WA Application Builder Insert
if (isset($_POST["Insert"])) // Trigger
$WA_connection = $HARS;
$WA_table = "markersponsormrt";
$WA_sessionName = "markersponsormrt_MrkrSpon_ID";
$WA_indexField = "MrkrSpon_ID";
$WA_fieldNamesStr = "MarkerID|SponsorID";
$WA_fieldValuesStr = "".$_SESSION['WADA_Insert_markers']  ."" . "|" . "".((isset($_POST["getSponsor"]))?$_POST["getSponsor"]:"")  ."";
$WA_columnTypesStr = "none,none,NULL|none,none,NULL";
$WA_fieldNames = explode("|", $WA_fieldNamesStr);
$WA_fieldValues = explode("|", $WA_fieldValuesStr);
$WA_columns = explode("|", $WA_columnTypesStr);
$WA_connectionDB = $database_HARS;
mysql_select_db($WA_connectionDB, $WA_connection);
  if (!
session_id()) session_start();
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$MM_editCmd = mysql_query($WA_Sql, $WA_connection) or die(mysql_error());
$_SESSION[$WA_sessionName] = mysql_insert_id();
  if (
$WA_redirectURL != "")  {
    if (
$WA_keepQueryString && $WA_redirectURL != "" && isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] !== "" && sizeof($_POST) > 0) {
$WA_redirectURL .= ((strpos($WA_redirectURL, '?') === false)?"?":"&").$_SERVER["QUERY_STRING"];
header("Location: ".$WA_redirectURL);
$WA_table = "markers";
$WA_sessionName = "WADA_Insert_markers";
$WA_indexField = "MarkerID";
$WA_fieldNamesStr = "MarkerNumber|MarkerName|MarkerCirca|MarkerAddress|MarkerCity|MarkerState|MarkerZip|MarkerLat|MarkerLong|MarkerTourDesc|MarkerShortDesc|MarkerLongDesc|MarkerThumb|MarkerImage|MarkerFeature|MarkerLive|MarkerComment|MarkerSponsor|MarkerUserID|MarkerUserIDUpdate|MarkerOriginationDate|MarkerUpdateDate";
$WA_fieldValuesStr = "".((isset($_POST["MarkerNumber"]))?$_POST["MarkerNumber"]:"")  ."" . "|" . "".((isset($_POST["MarkerName"]))?$_POST["MarkerName"]:"")  ."" . "|" . "".((isset($_POST["MarkerCirca"]))?$_POST["MarkerCirca"]:"")  ."" . "|" . "".((isset($_POST["MarkerAddress"]))?$_POST["MarkerAddress"]:"")  ."" . "|" . "".((isset($_POST["MarkerCity"]))?$_POST["MarkerCity"]:"")  ."" . "|" . "".((isset($_POST["MarkerState"]))?$_POST["MarkerState"]:"")  ."" . "|" . "".((isset($_POST["MarkerZip"]))?$_POST["MarkerZip"]:"")  ."" . "|" . "".((isset($_POST["MarkerLat"]))?$_POST["MarkerLat"]:"")  ."" . "|" . "".((isset($_POST["MarkerLong"]))?$_POST["MarkerLong"]:"")  ."" . "|" . "".((isset($_POST["MarkerTourDesc"]))?$_POST["MarkerTourDesc"]:"")  ."" . "|" . "".((isset($_POST["MarkerShortDesc"]))?$_POST["MarkerShortDesc"]:"")  ."" . "|" . "".((isset($_POST["MarkerLongDesc"]))?$_POST["MarkerLongDesc"]:"")  ."" . "|" . "".((isset($_POST["MarkerThumb"]))?$_POST["MarkerThumb"]:"")  ."" . "|" . "".((isset($_POST["MarkerImage"]))?$_POST["MarkerImage"]:"")  ."" . "|" . "".((isset($_POST["MarkerFeature"]))?$_POST["MarkerFeature"]:"")  ."" . "|" . "".((isset($_POST["MarkerLive"]))?$_POST["MarkerLive"]:"")  ."" . "|" . "".((isset($_POST["MarkerComment"]))?$_POST["MarkerComment"]:"")  ."" . "|" . "".((isset($_POST["MarkerSponsor"]))?$_POST["MarkerSponsor"]:"")  ."" . "|" . "".((isset($_POST["MarkerUserID"]))?$_POST["MarkerUserID"]:"")  ."" . "|" . "".((isset($_POST["MarkerUserIDUpdate"]))?$_POST["MarkerUserIDUpdate"]:"")  ."" . "|" . "".((isset($_POST["MarkerOriginationDate"]))?$_POST["MarkerOriginationDate"]:"")  ."" . "|" . "".((isset($_POST["MarkerUpdateDate"]))?$_POST["MarkerUpdateDate"]:"")  ."";
$WA_columnTypesStr = "',none,''|',none,''|none,none,NULL|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|none,none,NULL|none,none,NULL|',none,''|',none,''|none,none,NULL|none,none,NULL|',none,NULL|',none,NULL";
if (!
  if (
    if (
these two code blocks need to be switched so the marker is inserted before the sponsor.
Jim E D
Got it...
Thanks Jason, that's where DA put the code. So am I to assume it will always place this code at the top and I'll need to adapt?
Is there a document/tutorial for placing multiple inserts in a page that I'm missing?
it should order the inserts in the same way you add them to the page.
If you add the insert record behavior for the markers table to the page first, then add the insert for the sponsor, that is the order they should be in the code.
Dreamweaver implements a "Weighting" system that is used by DA to determine Server Behavior order, sometimes the Dreamweaver weighting system can go a bit off though.
