PowerMessenger 1.0.1 Upgrade - How To?
Thread began 6/06/2011 7:39 am by dave392376 | Last modified 6/15/2011 6:41 am by Jason Byrnes | 1577 views | 4 replies |
dave392376
I just downloaded the new upgrade, but there doesn't seem to be any documentation for installing the upgrade on an existing installation? I don't want to lose my settings, etc.
Could you post something about upgrade procedures? Thanks.
upload the updated files over the existing ones, you will overwrite everything except the connections folder.
then go into the instal_pm folder, and copy the install_pm/webassist folder, and over write the webassist folder at the power mailer root.
Steve
I wonder if future updates should not be a blanket reinstall as many of us will be needing to rewrite or add to the based code...
info290144
I did what you have said and here is want I get!
I'm not even able to access my admin area of the site.
Warning: require_once(../../Connections/PowerMailerConnection.php) [function.require-once]: failed to open stream: No such file or directory in /home/content/86/7732086/html/webassist/themes/theme_open.php on line 22
Fatal error: require_once() [function.require]: Failed opening required '../../Connections/PowerMailerConnection.php' (include_path='.:/usr/local/php5/lib/php') in /home/content/86/7732086/html/webassist/themes/theme_open.php on line 22
It looks like Ray fixed your issue in a support thread. It looks like you had copied Power Messenger Files over your Power Store Files.
