JavaScript Error when pressing the finish button
Thread begun 6/05/2011 9:52 am by designweb | Last modified 2/11/2012 11:37 am by i.edwards384429 | 9141 views | 13 replies |
designweb
When trying to create a site map from a remote URL: I am getting a javascript error when pressing the finish button.
You can view the error in the attached img.
Delete the Dreamweaver Cache file from the users configuration folder:
danny405167
I have deleted the cache file several times and I still not able to have Surveyor create my site. I have tried to do the following:
1) Add sites manually
2) Add one page to the site map
Nothing has worked.
So far I have two extensions that are not working as they should . Can you please help.
danny405167
Please help
I have been trying to solve my problem with the extension Surveyor but it just does not want to work on my PC. I have deleted the cache file several times and uninstalled and installed but nothing seems to work.
This morning I did a test on my Imac and to my surprise it worked. I being noticing that some extensions work flawlessly on my PC and others do not.
For example,
1) Image resizer works great on my PC but not on my IMac
2) Universal Email 4 works great on my PC but not on my Imac
3) Surveyor does not work on my PC but it works great on IMac
The extensions mentioned above are the ones that I have worked with so far on my PC and IMac.
Any chance you can add video tutorials for those like me that are having problems with Super suit extensions? In the meantime I will have to wait till my ticket gets resolve. I have posted my work and cell number and I can be reached anytime between 7 am and 4 pm.
By the way at work I am running Windows 7 Pro / CS 4 and at home I am running Snow Leopard / CS 5.
Thanks and hopefully I get some help pretty soon.
eSquareDesign
same error
I get the same Java Script error on hitting the finish button. Surveyor worked the first time I used it, and hasn;t worked since. i have tried it on several different projects, and get the same error.
I have deleted the .dat file and reinstalled the add on. Still getting the same error.
i.edwards384429
me too
Hi Jason
I'm getting the same error and I have also deleted the cache
working on a windows 7 machine 64bit with 8gb memory
thanks
Ian
what version of Dreamweaver?
i.edwards384429
update
Hi Jason
sorry using cs5
Ian
