Not sending in a CRON job
Thread begun 6/04/2011 2:24 pm by Paul | Last modified 6/07/2011 11:24 am by Jason Byrnes | 3136 views | 5 replies |
PaulBeta Tester
I have a cron job setup to execute my page 'auto-mail.php'
The page comprises of a recordset to pull my users and UE4 uses this to generate the mail and send if its not empty. Simple enough
When I load this pagemanually from the browser, id expect it to run, but it doesn't.
I added a dynamic table to display the recordset result - the email recipients and that doesn't run, so i just added some text in the body and that text doesn't display either.
All i get is a blank page with no errors.
Very odd.
any ideas?
zip attached.
Paul
If a page displays blank in the browser, it means there is an error on the page but error reporting is turned off.
add the following code at line 1 to turn error reporting on:
error_reporting
(E_ALL);
one problem I see in the code is that the Go to page is set to redirect back to itself. that means that if it does end the email out, it going to redirect back to itself afterwards, which will trigger the email to be sent again.
That redirect will send the page into an endless loop.
PaulBeta Tester
Thanks for response Jason.
Code added and file attached containing page output
I also changed the gotopage to my index.php
Paul
please send a copy of the webassist/email/waue_mail_1.php and webassist/email/templates/Block.php pages.
PaulBeta Tester
Files attached
