formtoolkit applied to page created with data assist
Thread begun 6/04/2011 3:00 am by Base5 Designs | Last modified 6/06/2011 2:02 pm by Jason Byrnes | 4606 views | 8 replies |
Base5 Designs
hi there i am really stuggling with this.
i have pages created with datya assist using a template.
all pages are created and working ok, i am now trying to apply client validation.
the form submits without validating i mange to carch the following js error just before the redirect when the form is submitted:
WAAlertErrors is not defined
i'm assuming that because the page is based on a template the file that is needed for the validation is not included in the page.
how do i work arround this, or alternativly what do i need to include manually to allow the validation to work
Base5 Designs
Ive done a search across my whole site and it only finds WAAlertErrors in the page i have the validation applied too, so i take it i am missing some files or something??? how can this be called if it is not defined anywhere???
please send a copy of your page so I can take a look at the code.
Base5 Designs
Hi Jason
after adding the the client validation from the toolbar this is the full page code that is generated.
firebug reports the following js error: WAAlertErrors is not defined
1
Line 3
although you have to press escape just after submitting to catch this as it redirects back to the results page...
<?php require_once('../../Connections/albionwines.php'); ?>
<?php require_once("../../WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
// WA Application Builder Insert
if (isset($_POST["Insert_x"])) // Trigger
$WA_connection = $albionwines;
$WA_table = "drinkcats_dct";
$WA_sessionName = "WADA_Insert_drinkcats_dct";
$WA_redirectURL = "../../drinkcats_dct_Results.php";
if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
$WA_keepQueryString = false;
$WA_indexField = "id_dct";
$WA_fieldNamesStr = "title_dct";
$WA_fieldValuesStr = "".((isset($_POST["title_dct"]))?$_POST["title_dct"]:"") ."";
$WA_columnTypesStr = "',none,''";
$WA_connectionDB = $database_albionwines;
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$_SESSION[$WA_sessionName] = mysql_insert_id();
if ($WA_redirectURL != "") {
<html xmlns="http://www.w3.org/1999/xhtml"><!-- InstanceBegin template="/Templates/index-admin.dwt.php" codeOutsideHTMLIsLocked="false" -->
<head>
<!-- InstanceBeginEditable name="doctitle" -->
<title>Insert Drink Category</title>
<!-- InstanceEndEditable -->
<script type="text/javascript" src="../../CSSMenuWriter/cssmw/menu.js"></script>
<style type="text/css" media="all">
@import url("../../CSSMenuWriter/cssmw/menu.css");
</style>
<!--[if lte IE 6]>
@import url("../CSSMenuWriter/cssmw/menu_ie.css");
</style>
img, div, ul, li, span, a {
behavior: url("../CSSMenuWriter/cssmw_images/iepngfix.htc");
</style>
<![endif]-->
<link href="../css/admin.css" rel="stylesheet" type="text/css" />
<!-- InstanceBeginEditable name="head" -->
<link href="../../WA_DataAssist/styles/Traditional_Slate.css" rel="stylesheet" type="text/css" />
<link href="../../WA_DataAssist/styles/Arial.css" rel="stylesheet" type="text/css" />
function WAtrimIt(theString,leaveLeft,leaveRight) {
if (!leaveLeft) {
while (theString.charAt(0) == " ")
theString = theString.substring(1);
if (!leaveRight) {
while (theString.charAt(theString.length-1) == " ")
theString = theString.substring(0,theString.length-1);
return theString;
function WAFV_GetValueFromInputType(formElement,inputType,trimWhite) {
var value="";
if (inputType == "select") {
if (formElement.selectedIndex != -1 && formElement.options[formElement.selectedIndex].value && formElement.options[formElement.selectedIndex].value != "") {
value = formElement.options[formElement.selectedIndex].value;
else if (inputType == "checkbox") {
if (formElement.length) {
for (var x=0; x<formElement.length ; x++) {
if (formElement[x].checked && formElement[x].value!="") {
value = formElement[x].value;
break;
else if (formElement.checked)
value = formElement.value;
else if (inputType == "radio") {
for (var x=0; x<formElement.length; x++) {
break;
else if (inputType == "radiogroup") {
break;
else if (inputType == "iRite") {
var theEditor = FCKeditorAPI.GetInstance(formElement.name) ;
value = theEditor.GetXHTML(true);
else {
var value = formElement.value;
value=value.replace(/<p>(\&\#160\;)*<\/p>/,"");
if (trimWhite) {
value = WAtrimIt(value);
return value;
function WAAddError(formElement,errorMsg,focusIt,stopIt) {
if (document.WAFV_Error) {
document.WAFV_Error += "\n" + errorMsg;
else {
document.WAFV_Error = errorMsg;
if (!document.WAFV_InvalidArray) {
document.WAFV_InvalidArray = new Array();
document.WAFV_InvalidArray[document.WAFV_InvalidArray.length] = formElement;
if (focusIt && !document.WAFV_Focus) {
document.WAFV_Focus = focusIt;
if (stopIt == 1) {
document.WAFV_Stop = true;
else if (stopIt == 2) {
formElement.WAFV_Continue = true;
else if (stopIt == 3) {
formElement.WAFV_Stop = true;
formElement.WAFV_Continue = false;
function WAValidateRQ(formElement,errorMsg,focusIt,stopIt,trimWhite,inputType) {
var isValid = true;
if (formElement.length && inputType.toLowerCase()!="radio" && inputType.toLowerCase()!="select") formElement=formElement[0];
if (!document.WAFV_Stop && !formElement.WAFV_Stop) {
var value=WAFV_GetValueFromInputType(formElement,inputType,trimWhite);
if (value == "") {
isValid = false;
if (!isValid) {
WAAddError(formElement,errorMsg,focusIt,stopIt);
</script>
</head>
<body>
<div id="adminmenu">
<?php require_once("../../CSSMenuWriter/cssmw/menu.php"); ?>
</div>
<div id="admincontent">
<!-- InstanceBeginEditable name="admincontent" -->
<div class="WADAInsertContainer">
<form action="Insert.php" method="post" name="WADAInsertForm" id="WADAInsertForm" onsubmit="WAValidateRQ(document.WADAInsertForm.title_dct,'-Title is required',document.WADAInsertForm.title_dct,0,true,'text');WAAlertErrors('The following errors were found','Correct invalid entries to continue',true,false);return document.MM_returnValue">
<div class="WADAHeader">Insert Drink Category</div>
<div class="WADAHorizLine"><img src="../../WA_DataAssist/images/_tx_.gif" alt="" height="1" width="1" border="0" /></div>
<table class="WADADataTable" cellpadding="0" cellspacing="0" border="0">
<tr>
<th class="WADADataTableHeader">Title:</th>
<td class="WADADataTableCell"><input type="text" name="title_dct" id="title_dct" value="" size="32" /></td>
</tr>
</table>
<div class="WADAButtonRow">
<table class="WADADataNavButtons" border="0" cellpadding="0" cellspacing="0">
<tr>
<td class="WADADataNavButtonCell" nowrap="nowrap"><input type="image" name="Insert" id="Insert" value="Insert" alt="Insert" src="../../WA_DataAssist/images/Slate/Traditional_insert.gif" /></td>
<td class="WADADataNavButtonCell" nowrap="nowrap"><a href="../../drinkcats_dct_Results.php" title="Cancel"><img border="0" name="Cancel" id="Cancel" alt="Cancel" src="../../WA_DataAssist/images/Slate/Traditional_cancel.gif" /></a></td>
</tr>
</table>
<input name="WADAInsertRecordID" type="hidden" id="WADAInsertRecordID" value="" />
</div>
</form>
</div>
</div>
</body>
<!-- InstanceEnd --></html>
please compress the page into a zip archive rather than pasting the page code to your message.
Base5 Designs
file in zip as requested
add the following code just before the closing </script> tag:
function WAAlertErrors(errorHead,errorFoot,setFocus,submitForm,allowOverride)  {
if (!document.WAFV_StopAlert) {
document.WAFV_StopAlert = true;
if (document.WAFV_InvalidArray) {
var errorMsg = document.WAFV_Error;
if (errorHead!="")
errorMsg = errorHead + "\n" + errorMsg;
if (errorFoot!="")
errorMsg += "\n" + errorFoot;
document.MM_returnValue = false;
if (document.WAFV_Error!="") {
if (allowOverride) {
if (confirm(errorMsg.replace(/&quot;/g,'"'))) {
document.MM_returnValue = true;
return;
else {
alert(errorMsg.replace(/&quot;/g,'"'));
else if (submitForm)
submitForm.submit();
if (setFocus && document.WAFV_Focus) {
if (document.getElementById(document.WAFV_Focus.name+"___Config") && document.WAFV_Focus.type.toLowerCase() == "hidden") {
var theEditor = FCKeditorAPI.GetInstance(document.WAFV_Focus.name);
theEditor.EditorWindow.focus();
setTimeout("setTimeout('document.WAFV_Stop = false;document.WAFV_StopAlert = false;',1)",1);
else {
document.tempFocus = document.WAFV_Focus;
setTimeout("document.tempFocus.focus();setTimeout('document.WAFV_Stop = false;document.WAFV_StopAlert = false;',1)",1);
else {
for (var x=0; x<document.WAFV_InvalidArray.length; x++) {
document.WAFV_InvalidArray[x].WAFV_Stop = false;
else {
if (submitForm) {
document.WAFV_Focus = false;
document.WAFV_Error = false;
document.WAFV_InvalidArray = false;
Base5 Designs
thanks for your reply, the code works
although thats a lot of code to be adding after applying the behaviour. i assume that the extension should be adding this too the page, is this a bug in the extension?
or is it an issue because i am using a template?
Honestly, I cannot say why the code is not being added. I cannot reproduce the problem on my end. if it where a problem with the template, the page would be mising more than the single function, so i dont believe it is a problem with the template.
perhaps try uninstalling form builder than installing again and deleting the dreamweaver cache file:
