URGENT HELP! coupon code screws up shipping
Thread begun 6/03/2011 2:18 pm by sam308940 | Last modified 6/06/2011 8:13 am by Jason Byrnes | 3176 views | 6 replies |
sam308940
Hi
on may 19 i added a coupon code. here is the code added:
//eCart Rule
function WAEC_JULES_LUCKY6() {
$totalDiscount = 0;
if (true && ((sizeof($this->Items) > 0) && ($this->InCart("SS2411") == true) && (((isset($_SESSION['discount_code'])?$_SESSION['discount_code']:"") == "lucky6")) OR ((isset($_SESSION['discount_code'])?$_SESSION['discount_code']:"") == "LUCKY6"))) {
$totalDiscount += ($this->ConditionalTotal("TotalPrice", "ID", "SS2411") * .3);//Result
return WA_eCart_FormatNumber($totalDiscount, $this->ForceDecimalsC, $this->DecimalPlacesC);
//eCart Rule
PROBLEM
on the view cart page it will show the shipping costs, and the subtotal including the shipping costs. However when you get to the confirm order page, NO SHIPPING is shown and its not included in the total either. This changed in the orders on the EXACT date the coupon code above was added.
The confirm order page & the checkout page, have not changed since March. So im fairly certain its nothing there that is causing this. It has to be something on the view cart page. HOWEVER the view cart page is the one page that shows the total correct.
?????? Any ideas on what is causing this? SInce may 19 its happened to every order and that shipping has added up! SIGH!!!!!! BIG MONEY LOST. Im freaking out.
Im attaching my files.
and you can test the live url at julesreid.com
add any item to the cart
see the shipping in the cart
then checkout
on the confirm page - no shipping shows
thanks
sam
the problem occurs on the https transfer to the secure checkout page. The cart transfer form does not transfer either the coupon or shipping.
to fix this edit the cart_checkoutphp file. Change the following line:
[php<input type="hidden" name="Size_<?php echo $JULES_Index; ?>" id="Size_<?php echo $JULES_Index; ?>" value="<?php echo $JULES->DisplayInfo("Size") ?>" />[/php]
<input type="hidden" name="Size_<?php echo $JULES_Index?>" id="Size_<?php echo $JULES_Index?>" value="<?php echo $JULES->DisplayInfo("Size"?>" />
<input type="hidden" name="ship_method" id="ship_method" value="<?php echo(isset($_SESSION["ship_method"])?$_SESSION["ship_method"]:""?>" />
<input type="hidden" name="discount_code" id="discount_code" value="<?php echo(isset($_SESSION["discount_code"])?$_SESSION["discount_code"]:""?>" />
sam308940
im sorry but i am not follow.
i cannot find the code you reference in my file on the cart_checkout page.
also - that file has not changed since march. and the shipping was charging up to may 19. SO - it was working up to May 19........?
sam308940
SORRY
i got it 2 seconds after that message.
i did find that code (on waht i call cart view page).
SIGH i suppose it got delete at some point?
if it was working before it had to have been being passed to the secure checkout?
frustrating!
I cant really speak to why it was working before, then stopped. All I can really do is look at the code you posted and try to spot what is wrong based on the description you provide.
If there was no code change at all, then it should not have been working before.
Does the code change I suggested fix the issue?
sam308940
yes the code you gave me worked.
i was trying to figure out if i caused issue when working in the file.
im frustrated with myself to think i could have deleted those to fields erroneously.
OK, glad to hear it is working.
