grey map
Thread begun 6/03/2011 8:29 am by fabrizioripesi426077 | Last modified 6/10/2011 12:05 pm by Jason Byrnes | 5853 views | 10 replies |
grey map
Hi, I have a problem.
With a static map no problem but with a dynamic one I have this problem, a grey map:mappa-Appartamenti-Roma2.asp
As you can see a t the bottom of the browes is signaled error.
Can you help me?
P.S.: IT works only if I push on the only marker is visible
send a copy of the google_maps/wagmp_map_1asp file so i can take a look at the code please.
Here the zip file required.
Pro maps for google and spry tab
I have noticed that the problem about pro google maps , when the maps are inside a spry tab, is that the first map I search in the menu tab is ok, the second one not (it appears with grey areas, sometimes full grey)
Can you help me to solve this problem?
see this thread for a fix:
showthread.php?t=13541
no solution
What's the problem? Why is grey now? It happens woth dynamic records. It's not more inside a tabbed panel.
please send a link where i can see the problem in a browser to troubleshoot.
appartamenti-Roma-zone.asp
Sorry...problem solved...there was a surplus code in conflict
Thanks!
