Logging in - still confused
Thread begun 6/02/2011 7:01 pm by jen425288 | Last modified 6/06/2011 7:06 am by Jason Byrnes | 2295 views | 3 replies |
jen425288
Our system requires that only the admin has access to the Profile page, for updating user records and adjusting user levels. So it is set for "Admin" access only. But just to get the log-in working, I entered the Profile page for "If log in succeeds, go to:". And when I log in (as administrator), I get directed to the Profile page (ie, it works).
But if anyone else logs in, I don't want them going to that page. I just want them being sent to the page they were trying to access that triggered the Log In page.
How do I achieve this? In the Authenticate user server behaviour I have left checked (default setting) the "Go to previous URL (if it exists)" and "Pass original query string on redirect" checkboxes although I don't know what they mean (!).
At the moment, if anyone except Admin logs in, they get "Object not found... Error 404".
the "Go to previous URL (if it exists)" option is triggered by sending the path to the previous page through a querystring variable named "accesscheck", for example, if I try to access a protected page, I get redirected to the login page with a URL looking like:
login.php?accesscheck=%2Fps_4_5%2Fadmin%2Fhome.php%3F
this tells the login behavior to redirect me back to
home.php
on successful login. For this to work, however, the querystring must be passed when the login form posts. make sure the foloowing coded is used for the forms action:
<?php echo ($_SERVER["PHP_SELF"].(isset($_SERVER["QUERY_STRING"])?"?".htmlentities($_SERVER["QUERY_STRING"]):""));?>
for example, the login for tag should look like:
<form  action="<?php echo ($_SERVER["PHP_SELF"].(isset($_SERVER["QUERY_STRING"])?"?".htmlentities($_SERVER["QUERY_STRING"]):""));?>" method="post" name="WAATKLogInForm" id="WAATKLogInForm">
jen425288
That code was correct. Over the weekend I started over and now it appears to be working, thank you.
you're welcome.
