textfieldInvalidFormatMsg
Thread begun 6/02/2011 7:13 am by info4753 | Last modified 6/06/2011 7:36 am by info4753 | 3206 views | 4 replies |
info4753
Where can I change the Invalid Format message? Is there a language file where I can use another basic language instead of english?
all of the error messages are set in the HTML code ogf the page, for example the invalid format error code may look like:
<span class="textfieldInvalidFormatMsg">Invalid format.</span>
you can change that directly in the HTML:
<span class="textfieldInvalidFormatMsg">You have entered an Invalid format.</span>
No, there is not a language file that can be edited, you would need to manually translate the error messages.
info4753
Thanks Jason. That's what I found so far. Might to be considered from your side for the next update.
Are the messages hardcoded or can I change the basic (english) file somewhere into german?
the messages are hard coded, there is no language file.
info4753
That's weak. Even the 5 years old ADDT had it...
Please add this for the next update. Thanks.
