Font Problems
Thread begun 6/01/2011 5:06 pm by rlittle312981 | Last modified 6/08/2011 6:31 am by Jason Byrnes | 6048 views | 15 replies |
rlittle312981
Font Problems
How do you get the security codes fonts to work under Apple 10.6 Server. In a contact page I get a blank doc.
can you send a link where i can see the problem.
rlittle312981
Link
contactus.php
MACTYPE.TTF
users_registration.php
and any other link that has a security code link.
Thanks Randy
looks like a php error is occurring when trying to generate the captcha image.
add the following code at line 1 of the WA_ValidationToolkit/WAVT_CaptchaSecurityImages.php file:
error_reporting
(E_ALL);
rlittle312981
Code
I added the code but it did not fix anything. Im lost. please let me know what you find.
Thanks Randy
the code suggestion wasn't intended as a fix, it was intended to turn error reporting on so that we could see what the problem was to be able to suggest a fix.
I dont believe the code was applied correctly, the WA_ValidationToolkit/WAVT_CaptchaSecurityImages.php? file now just shows the code.
I think that you may have removed one of the opening "<?php" brackets when adding the error reporting code.
rlittle312981
Re did file
Hi Jason
I re-did file. ----------- Thanks Randy.
error_reporting(E_ALL);
php
session_start();
class WA_Captcha {
function randomString($numChars) {
$useChars = '2345679bcdhkmnrstwxzADEFHJKLMNPRSTWXYZ';
$str = '';
for ($x = 0; $x < $numChars; $x++) {
$str .= substr($useChars, rand(0, strlen($useChars)-1), 1);
return $str;
function hexToRGB($color) {
if ($color[0] == '#')
$color = substr($color, 1);
if (strlen($color) == 6)
list($r, $g, $b) = array($color[0].$color[1],
$color[2].$color[3],
$color[4].$color[5]);
elseif (strlen($color) == 3)
list($r, $g, $b) = array($color[0].$color[0], $color[1].$color[1], $color[2].$color[2]);
else
return false;
$r = hexdec($r); $g = hexdec($g); $b = hexdec($b);
return array($r, $g, $b);
function addGrid($image,$freq,$width,$height,$color) {
if ($freq != 0) {
$frequency = (101-$freq);
// horizontal line
$numLines = ceil($height/$frequency);
$shift = rand(1,$frequency-1);
for( $i=0; $i<$numLines; $i++ ) {
imageline($image, 0, ($frequency*$i)+$shift, $width, ($frequency*$i)+$shift, $color);
// vertical line
$numLines = ceil($width/$frequency);
imageline($image, ($frequency*$i)+$shift, 0, ($frequency*$i)+$shift, $height, $color);
// backslash line
imageline($image, ($frequency*$i)+$shift+$frequency, 0, ($frequency*$i)+$shift, $height, $color);
// slash line
imageline($image, ($frequency*$i)+$shift, 0, ($frequency*$i)+$shift+$frequency, $height, $color);
function addNoise($image,$freq,$width,$height,$color) {
if ($freq != 0) {
$frequency = $freq;
// random noise
$noiseSpots = ($width*$height*($frequency/20))/5;
for( $i=0; $i<$noiseSpots; $i++ ) {
imagefilledellipse($image, rand(0,$width), rand(0,$height), 1, 1, $color);
// random line
$numLines = (($height/60)*sqrt($width*$height)*($frequency/20))/5;
imageline($image, rand(0,$width), rand(0,$height), rand(0,$width), rand(0,$height), $color);
function WA_Captcha($width,$height,$characters,$bg_color,$text_color,$noise_color,$font,$field,$transparent,$bgimage,$gridfreq,$grid_color,$gridorder,$noisefreq,$noiseorder,$charheight) {
$font = realpath($font);
$font_size = $charheight;
if ($bgimage != "") {
$image_size = getimagesize($bgimage);
if (strpos($bgimage,".gif") > 0) {
$captchaBG = imagecreatefromgif($bgimage);
else if (strpos($bgimage,".png") > 0) {
$captchaBG = imagecreatefrompng($bgimage);
else {
$captchaBG = imagecreatefromjpeg($bgimage);
$captcha = imagecreatetruecolor($width, $height);
$ystart=0;
$bgColor = $this->hexToRGB($bg_color);
$txtColor = $this->hexToRGB($text_color);
$noiseColor = $this->hexToRGB($noise_color);
$gridColor = $this->hexToRGB($grid_color);
$background_color = imagecolorallocate($captcha, $bgColor[0], $bgColor[1], $bgColor[2]);
$text_color = imagecolorallocate($captcha, $txtColor[0], $txtColor[1], $txtColor[2]);
$noise_color = imagecolorallocate($captcha, $noiseColor[0], $noiseColor[1], $noiseColor[2]);
$grid_color = imagecolorallocate($captcha, $gridColor[0], $gridColor[1], $gridColor[2]);
imagefilledrectangle($captcha,0,0,$width,$height,$background_color);
if ($transparent == 1) imagecolortransparent($captcha, $background_color);
while($ystart<=$height) {
$xstart=0;
while($xstart<=$width) {
imagecopy($captcha, $captchaBG, $xstart, $ystart, 0, 0, $image_size[0], $image_size[1]);
$xstart += $image_size[0];
$ystart += $image_size[1];
if ($noiseorder != "in front of text") {
$this->addNoise($captcha,$noisefreq,$width,$height,$noise_color);
if ($gridorder != "in front of text") {
$this->addGrid($captcha,$gridfreq,$width,$height,$grid_color);
$captcha_string = $this->randomString($characters);
$y = -1;
while ($y < 0 || ($textbox[4] > $width)) {
$textbox = imagettfbbox($font_size, 0, $font, $captcha_string);
$y = ($height - $textbox[5])/2;
if ($y < 0 || ($textbox[4] > $width)) {
$font_size = 0.9 * $font_size;
$totWidth = 0;
$charWidths = array();
for ($charLen=0;$charLen<$characters;$charLen++) {
$tilt = rand(-15,15);
$charWidth = imagettfbbox($font_size, $tilt, $font, $captcha_string[$charLen]);
$tilts[] = $tilt;
$charWidths[] = $charWidth[4];
$totWidth += $charWidth[4];
$space = ($width-$totWidth)/($characters+2);
$x = $space*1.5;
imagettftext($captcha, $font_size, $tilts[$charLen], $x, $y, $text_color, $font , $captcha_string[$charLen]);
$x += $charWidths[$charLen]+$space;
if ($noiseorder == "in front of text") {
if ($gridorder == "in front of text") {
header('Content-Type: image/png');
imagepng($captcha);
imagedestroy($captcha);
$_SESSION["captcha_".$field] = $captcha_string;
$width = isset($_GET['width']) && $_GET['width'] != "" ? $_GET['width'] : '120';
$height = isset($_GET['height']) && $_GET['height'] != "" ? $_GET['height'] : '40';
$characters = isset($_GET['characters']) && $_GET['characters'] > 2 ? $_GET['characters'] : '5';
$bgcolor = isset($_GET['bgcolor']) && $_GET['bgcolor'] != "" ? $_GET['bgcolor'] : 'FFFFFF';
$textcolor = isset($_GET['textcolor']) && $_GET['textcolor'] != "" ? $_GET['textcolor'] : '000000';
$noisecolor = isset($_GET['noisecolor']) && $_GET['noisecolor'] != "" ? $_GET['noisecolor'] : '000000';
$font = isset($_GET['font']) && $_GET['font'] != "" ? $_GET['font'] : 'Fonts/MOM_T___.TTF';
$field = isset($_GET['field']) && $_GET['field'] != "" ? $_GET['field'] : '1';
$transparent = isset($_GET['transparent']) && $_GET['transparent'] != "" ? $_GET['transparent'] : '0';
$bgimage = isset($_GET['bgimage']) && $_GET['bgimage'] != "" ? $_GET['bgimage'] : '';
$gridfreq = isset($_GET['gridfreq']) && $_GET['gridfreq'] != "" ? $_GET['gridfreq'] : '50';
$gridcolor = isset($_GET['gridcolor']) && $_GET['gridcolor'] != "" ? $_GET['gridcolor'] : '000000';
$gridorder = isset($_GET['gridorder']) && $_GET['gridorder'] != "" ? $_GET['gridorder'] : '';
$noisefreq = isset($_GET['noisefreq']) && $_GET['noisefreq'] != "" ? $_GET['noisefreq'] : '50';
$noiseorder = isset($_GET['noiseorder']) && $_GET['noiseorder'] != "" ? $_GET['noiseorder'] : '';
$charheight = isset($_GET['charheight']) && $_GET['charheight'] != "" ? $_GET['charheight'] : $height*0.75;
Fonts/MACTYPE.TTF
Fonts/MODERNA_.TTF
Fonts/MOM_T___.TTF
Fonts/monofont.ttf
$captcha = new WA_Captcha($width,$height,$characters,$bgcolor,$textcolor,$noisecolor,$font,$field,$transparent,$bgimage,$gridfreq,$gridcolor,$gridorder,$noisefreq,$noiseorder,$charheight);
you're changing the code at line 5 though.
line 5 should be a new php block
change:
error_reporting
(E_ALL);
php
error_reporting
(E_ALL);
rlittle312981
Fixed
Sorry, I'm not a code writer.
I think this is fixed.
Thanks Randy
OK, now when visiting the captcha page:
it shows the following error:
Fatal error: Call to undefined function imagettfbbox() in /Library/WebServer/jeffcou/store/WA_ValidationToolkit/WAVT_CaptchaSecurityImages.php on line 129
this error means that either the GD or True Type libraries have not been enabled in the PHP server settings. you will need to contact the host to have them enable both the GD and true Type libraries.
