Checkbox problem
Thread began 6/01/2011 7:16 am by scott417485 | Last modified 6/02/2011 7:10 am by Jason Byrnes | 1030 views | 3 replies |
scott417485
Checkbox problem
Hi Guys
I have a form that inputs the data back to a database, all info is working correctly with the exception of the 3 checkboxes on the form.
The terms and conditions check box group always returns a value of "N" back to the database for both checkboxes on line 948.
And the Tax invoice (line 1027) required check box alway returns a vale of "Y" and the default display always shows as checked, even though, as far as I can tell it is set to a default display of unchecked.
I have attached the code, any help would be greatly appreciated, I think I am missing something obvious.
cheers
scott
for the terms and conditions check boxes, you should not use a check box group like you have done, you should use two separate uniquely named check boxes instead.
for the And the Tax invoice, you have not specified a checked value.
scott417485
hi jason
manyj thanks, will change them
cheers
scott
you're welcome.
