Checkout
Thread begun 5/31/2011 9:42 pm by cicyou421883 | Last modified 6/09/2011 6:55 am by Jason Byrnes | 7624 views | 13 replies |
cicyou421883
Checkout
My products checkout on localhost, not remote server. I have synchromized the site files and the database. Checkout on the remote stays on the following page
confirm.php
does not go to the checkout_Success.php as the localhost does do...
authorize.net worked for localhost. Does this have to do with the previewdns? On localhost, authorize.net works.
Database on remote shows order and orderdetails, but did not go to the authorize.net to checkout_Success.php...
code on confirm.php page on both testing and remote:
$WAGatewayResponse = AuthNet_Post($AuthNet_required,$AuthNet_itemized,$AuthNet_optional);
if ($WAGatewayResponse) {
$californianatural->redirStr = "checkout_success.php";
else if ("checkout_failure.php" != "") {
header("Location: ". "checkout_failure.php");
exit();
if the confirm page is not redirecting, it is likely a php error occurring, add the following code at line 1 of the confirm page to turn error reporting on:
error_reporting
(E_ALL);
cicyou421883
POSTED error code
This message came up on the remote server. Testing sever is able to get to authorize.net.
Could it be because I am using a previewdns with GoDaddy Hositng that the confirm page does not authorize.net which may mean I have to be online? I understand that you may not know of the GoDaddy functions. Just trying to make sure that the Webassist pages are working before I have to go live.
error:
Service Temporarily Unavailable
The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.
Thank you, CATHY
I certainly could be the preview DNS, I cant really say, I've never used that service before.
if it is storing the database info, but not passing the order to autohorize.net, I would guess that the "Service Temporarily Unavailable" that the error is talking about is the cURL service, it sounds like the server is having an issue with cURL,
cicyou421883
PHP Error
I have the site live now no preview DNS and the confirm page shows this error:
?php error_reporting(E_ALL); ini_set('display_errors','on'); ?>
Warning: Cannot modify header information - headers already sent by (output started at /home/content/54/7456454/html/confirm.php:5) in /home/content/54/7456454/html/confirm.php on line 486
Page link:
confirm.php
cicyou421883
Confirm.php page
The confirm page did go to authorize.net in the test mode. Is this a a cURL issue? I am calling GoDaddy.... to see how they can help.
cicyou421883
LINE 486 reads
Line 486 reads... in the below section - header("Location: ".$californianatural->redirStr);
if ($californianatural->IsEmpty()) {
$californianatural->redirStr = "../cart.php";
$californianatural->cartAction = "RedirectIfEmpty";
// WA eCart Redirect
if ($californianatural->redirStr != "") {
?><?php
Also, I added a shoppingcart.php page since My page was cart.php
Error now says:
I did have a paid session with RAY and this was supposed to have been corrected so that i would have a checkout. At this point, I am live and do not have a checkout.
this is bad code on the page.
you added the error reporting code missing a "," character.
at line 1 you have:
that code should be:
<?php error_reporting(E_ALL); ini_set('display_errors','on'); ?>
cicyou421883
Changed the error php on Page
Also I changed all pages to say ../cart.php including, the confirm, checkout, index, and users pages.
Current error is:
Warning: Cannot modify header information - headers already sent by (output started at /home/content/54/7456454/html/confirm.php:2) in /home/content/54/7456454/html/confirm.php on line 483
Lines 480 - 485, 5 lines says:
?><?php
cicyou421883
The Authorize.net says it is still in test mode....
The authorize and capture is confirming to my e-mail even thought the site stays on the confirm page. How do I get it out of the test mode. I changed hosting servers today and the old site was working with authorize.net fine. Somehow the pages that I used with webassist are still in test mode. Please advise.
