unknown column error with SA2 Login.php
Thread begun 5/31/2011 11:37 am by Dennis | Last modified 6/09/2011 12:31 pm by Jason Byrnes | 4234 views | 7 replies |
Dennis
I have tried at least three times to create a set of pages with SA2. Everytime when I test the Login page I get the error "Unknown column 'DennisTest' in 'where clause'" as the only thing displayed on the page.
This happens only with the remote website & database not with my localhost. The localhost database was created just prior to testing, using the SQLyog Copy Database utility.
To my knowledge 'DennisTest' does not exist in the database either as data or a column name.
Thanks,
Dennis
Dennis
More info
After noticing the Login page appears when accessing from another computer, I deleted cookies & form data from IE the page now works from my main computer.
However I also have the word "undefined" displayed as the beginning of the page as others have mentioned in another thread.
Additional concerns/questions...
I did not see a prompt to specify either, on failure or on success, redirects in the SA2 wizard.
On my installation NO help link was installed in the DreamWeaver Help menu.
How do you utilize a DW Template with the SA2 wizard.
Dennis
AlaskaTomBeta Tester
I tried this, and get the exact same errors on both login, and forgot password pages.
After walking through the generated code, and include files, I figured out how to echo back the generated query, and realized there were no quotes around the username and password field data in the query. This appears to be due to incorrect column types (blank column types) being passed to the WA_GetSQLValueString function as the query is being generated.
I looked through the generated code on my login page, and see that the column type is blank
"columnTypes" => explode($WA_Auth_Separator,"".$WA_Auth_Separator.""),
should be
"columnTypes" => explode($WA_Auth_Separator,"text".$WA_Auth_Separator."text"),
and on the forgot password page,
"columnType" => "",
should be
"columnType" => "text",
Since this bug makes the login function and forgot password function unusable, I assume that this happens only under certain circumstances.
I am running Dreamweaver CS5.5 on Windows XP pro.
Hopefully that will help them track it down.
Tom
Denis:
The success and failure are not specified in the wizard with version 2. Instead, version 2 handles login success and failure through messaging that is displayed on the page using authentication rules and the security assist show region behavior.
you can double click on the Security Assist Authenticate user behavior to change the success and failure behaviors.
the Security Assist help is under WebAssist -> Help -> SecurityAssist -> Help
it is also available on the security assist support page:
securityassist/
by clicking the "Built-In" Help link.
The template will need to be applied to the SecurityAssist pages after they are created.
for the other issues reported, I have created a support ticket so we can look into this issue further.
Dennis
Thanks Jason,
I do not have a ticket for this thread in my support history.
Dennis
should be there now.
Jediha
I confirm that in my first try the login page gave the same error and I found the same "solution" by putting text between the "".
A second try however gave a perfect login page. I remember that the first time I altered the login page by editing the authenticate user server behavior to add extra session variables.
Hope this helps tracking the bug down.
Hans
