Multiple Keywords Help
Thread begun 5/31/2011 10:20 am by doug425125 | Last modified 6/01/2011 8:01 am by Jason Byrnes | 1618 views | 1 replies |
doug425125
I'm trying to set up a keyword search with pages that have already been created with Data Assist. I have a search, result and detail page. These were set up, I'm assuming using the defaults for the search criteria. I'm not understanding the syntax of the "AND" "OR" , or how to edit the results page to include the keywords that are put into the edit box by the user. Should I use the Search Wizard to create new search pages, or just edit one of the existing pages to reflect this desired result? ie; apples, oranges, invoice I've been trying to edit the "DataAssist Search" window that comes up when I click on DataAssist Search (WADAxxx) , but have not been able to change the behaviour. It would great if I could set it up to behave like a Google search on my specified database table ie; apples +oranges +grapes
Doug
you can edit the existing search behavior, Make sure the comparison is set to Includes, and set the and separator of the key word search to ", " (whithout the quotes, the space after the coma is important)
if this is not working for you, send a copy of your search and results page in a zip archive so I can take a look at the code.
