Simple calculation
Thread begun 7/04/2009 11:46 pm by Russell Collins | Last modified 7/07/2009 5:09 am by Russell Collins | 2257 views | 2 replies |
russell355191Beta Tester
Simple calculation
I am creating an assets management app at the moment and am not sure what to do in order for a total to be put into a DA input field. Could I possibly use an eCart object?
Field 1 has the unit cost
Field 2 has the qty
In field 3 I would like a total automatically calculated as unit cost x qty to be inserted on submit.
Any pointers or help would be much appreciated.
Regards
Russ
You probably don't need a cart.
First, you probably don't want to insert into field3. If field3 by definition is equal to field1*field2, then storing it at all is just an opportunity for an error. Just store field1 and field2 in the database and if you want to use all three use a query like:
SELECT *, (field1 * field2) AS field3 FROM table
and even though you only stored field1 and field2 you can always get the value of field3 in your results.
Thanks Ray,
You are the spark that lights the fire!
Go WebAssist !
Regards
Russell Collins
