Multiple Possible discounts from 1 Coupon Code
Thread begun 5/30/2011 12:22 pm by psychobilly1165508 | Last modified 5/31/2011 12:12 pm by Jason Byrnes | 1612 views | 1 replies |
psychobilly1165508
I have an existing database driven coupon system that works great. However, I would like to be able to create one coupon code with multiple option, like 10% Off Sub-Total, Free Shipping, excluding categoryID = 2,4,10...
My Current Fields are:
Coupon_Name | Coupon_End_Date | Coupon_Amount
I added 2 more fields/options to store the selections:
Free_Shipping | Exclude_CatID
A field for Free Shipping (Yes or No) and a field to hold the Excluded category(s).
I've added a cart column called "exclude", and have it working with 1 category, but can't seem to figure out how to get this to work with multiple categories.
Also, not sure where to start with the "Free Shipping" in the eCart "Discount" tab as it would change the coupon calculation.
the exclude catid option will take some hand coding to accomplish, it should not be to difficult if you are comfortable hand coding PHP, if you need assitance putting it into place, I would sugest signing up for a premier ticket where we can work with you on a one to one basis.
you will need to have a catID and exclude column in your cart object.
In the set session variable code where you set the exclude catID session variable, you will need to use the explode() function to convert the comma separated list into an array, for example:
$_SESSION["exclude"] = explode(", ", $row_recordsetName['excludeCatID']);
then in the add to cart button, set the catID column of the cart object to store the catID column from the products table, you will then need to hand eddit the code to set the exclude cart column based on the exclude session array:
$ATC_itemexclude = "".(in_array($ATC_itemCatID, $_SESSION["exclude"])?1:0)."";// column binding
you can then set the discount rule to be based on the Subtotal of all items where the exclude column is equal a value of 1.
for the free shipping, you would need to create a new discount rule, set it to trigger if the free shipping session variable is equal to yes
use a flat rate calculation of:
$this->GetShipping()
