Errors on Conversion MSAccess to MYSQL
I have several domains built some years ago using MSAccess and ColdFusion that worked just fine.
I am converting all the databases to MYSQL but am getting SQL syntax errors with the code generated by DataAssist.
I tried to reopen the the DataAssist wizard and re-set the code but found no where to designate the type of database and the SQL errors persist.
How can I set the WebAssist code to deal with MYSQL syntax rather than MSAccess?
