Multiple Emails from selects
Thread begun 5/29/2011 5:52 am by vernon webb | Last modified 5/31/2011 11:23 am by Jason Byrnes | 4087 views | 7 replies |
vernon webb
I need to setup a form that allows users to select multiple users.
A recordset doesn't work because it contains all the users and I want the recipient to be selected by the user.
I thought I could setup a dynamic menu poplulated from the recordset and allow users to select multiple recipients from there, which works but only the last person selected receives it.
Any ideas on how to make this work? Thanks...
see this thread for details:
showthread.php?t=20790
the example given is for a static multiple select list, but it works exactly the same for a dynamic multiple select list.
vernon webb
This did not work for me. If I add the [] it doesn't work, but when they are not there it does, but only goes to one person, the last one on the list.
for the list to pass multiple selections, the name needs to end in "[]"
if the square brackets are not in place, only the last selection made is passed.
send a copy of your page with the "[]" in place so I can examine the code.
vernon webb
I do understand, however it didn't work for me. The page is attached
you missed this part from the thread i linked to:
  In universal email, when you bind to the email address form element, it will include the "[]" in the binding code:
<?php echo((isset($_POST["toAddresses[]"]))?$_POST["toAddresses[]"]:"") ?>
these should be removed from the binding code:
<?php echo((isset($_POST["toAddresses"]))?$_POST["toAddresses"]:"") ?>
on your page, find the following line of code:
$RecipArray[$CurIndex ][] = "".((isset($_POST["toAddresses[]"]))?$_POST["toAddresses[]"]:"")  ."";
and change it to:
$RecipArray[$CurIndex ][] = "".((isset($_POST["toAddresses"]))?$_POST["toAddresses"]:"")  ."";
vernon webb
That worked great, thanks
you're welcome.
