Universal Email and Dynamic Drop Down
Thread begun 5/28/2011 8:47 pm by kevin389160 | Last modified 6/07/2011 8:47 am by Jason Byrnes | 5076 views | 7 replies |
kevin389160
How do I get Universal Email to send emails to a list in Dynamic Dropdown? I've tried sending to the list in Dynamic Dropdown and also making the To field in my form a list and populating it from Dynamic Dropdown, but nothing seems to work. I've also tried to but in a static value in the list to see if I could get UE to send it and it wouldn't. Can UE send emails addresses that are in a list? If this is possible, how can I do it as I need to send from a list from Dynamic Dropdown?
make sure that the name of the multiple select list ends with "[]", for example:
<select name="toAddresses[]" size="5" multiple="multiple" id="toAddresses">
<option value="one@domain.com">email one</option>
<option value="two@domain.com">email two</option>
<option value="three@domain.com">email three</option>
<option value="four@domain.com">email four</option>
<option value="five@domain.com">email five</option>
</select>
In universal email, when you bind to the email address form element, it will include the "[]} in the binding code:
<?php echo((isset($_POST["toAddresses[]"]))?$_POST["toAddresses[]"]:"") ?>
these should be removed from the binding code:
<?php echo((isset($_POST["toAddresses"]))?$_POST["toAddresses"]:"") ?>
then add the following code at line 1:
if($_SERVER["REQUEST_METHOD"] == "POST")     {
    foreach(
$_POST as $key => $val) {
        if(
is_array($_POST[$key])) $_POST[$key] = implode(", ", $_POST[$key]);
kevin389160
The code that you asked me to put at line 1. Do you want me to put it before the database connection as that is one line 1 on my email form page with Dynamic Dropdowns?
that code should be at line 1, it should be the first code block on the page.
kevin389160
Thanks, that worked perfectly.
Now I have a questions that is on this same form but with the Dynamic Dropdown part. I am wanting to filter the Recordset that will fill the first List in my Dyanmic Dropdown. I want to fill in a text field that will be the form variable that filters the recordset. I already set the recordset to form variable and to begins with. Now how do I do the rest?
See the following for details on filtering a recordset by a form variable:
simple_search_feature03.html
kevin389160
Thanks Jason for your help, it's really helped and been a blessing.
you're welcome.
